RPM drop and temperature drop
stutzedward
3,416
561
You will solve the problem when you increase the RPM by adjusting the setting on the throttle body, however it will be very high when engine is cold. Anyway, I had similar problems previously and it was only resolved after replacing the ICV (Idle Control Valve
Seeking some expert help!!:embaressed_smile:
my spec as...1.6 local block using GTI head
- my question is, if I change to 4G93 wiring & ECU from 4G91..will it make any different on hp? is it suitable the fix in?:Not_Impressed:
