tried 2nd set half cut, tyre did lock..without it, lock abit later...so if it rains/wet road i'll drive below 100...and no tailgating if theres right lane quite a few cars ahead...diff story for lane hogger.
its for my wife car,so mid range should be fine.. hahaha...ecopia ep300 or v2 concept 2 better?
yea...hahaha...but gyfa3 above 400...out of budget unless i got promoted..hahaha..ps3 will do
I'm of the opinion to always buy the best tire one can afford. Therefore if you can afford better performance tires, say the V12 Evo2 (which is still relatively cheap), why settle for the lower V2 Concept 2? Think about it, even if your wife does not drive fast, but there might be some instances whereby she needs to drive in heavy rain, or do emergency braking or accident avoidance maneuvering. So in those cases, would you rather equip her with the better performance/grip tires or just settle with those low end cheaper ones?? Remember also that your wife probably would not be as skillful as you, so in those situations shouldn't you equip her with even better than or at least similar with what you actually use yourself?? Choose wisely bro!
