Balik pulau road nice....mid way can stop at big water reservoir...
Feel planted, and I not kaki corner....but once a while hantam also. Ftuned price also not bad.
I ask halfcut for tein, 3.5 - 4k. Walao...plus service, big hole on wallet.
Actual is spring rate....if have correct rate, will be easy on the shocks.
One thing, always play with dampening setting.
Crawl loh...Ftuned using inverted monotube.
Again, I should join ZTH earlier.... Hahahaha..
His is because he mod engine bay with piping, no place for battery. If your engine bay can accommodate the battery leave it there, or you can do a heat shield for the battery
---------- Post added at 03:55 PM ---------- 6 hour anti-bump limit - Previous post was at 03:54 PM ----------
Got to ask bro. sweelt, since he is from Penang I just post balik pulau.......lol
battery does emit fumes, so u need some ventilation.
How's the road condition at balik pulau? What kinda speed one can be averaging there? yeah f-tuned really caught my attention, did you went back to fine tune on the damper valving or one shot got it right?
One shot right...susah loh.
Crawl many tims dy, hahaha....
At the end have to compensate some lobang...no stock comfort.
Balik pulau road, lots of corner. But not empty road...I don want to jungle rally with wira.
Scenery is nice, yeah..
does battery relocation to the rear, really helps with the car weight distribution?
why always on the right and not the centre?
temporary put everything in, to get clear picture for final detailing.
I also get some tube and fitting, foc, hahaha...it seems that battery have 2 vent hole.
Too messy, i think. Will get enclose box at tesco / aeon later. Make venting tube, quite a challenge.
Put center boot space wasted......lol
---------- Post added at 10:57 PM ---------- 6 hour anti-bump limit - Previous post was at 10:55 PM ----------
Why not used the rectangle metal battery holder?
on the way, battery holder. Current one, saja want to find idea. So far battery stay put.
battery relocation, name is easy...time to source parts very slow.![]()
actually, apart from prolonging the battery life if were to place at rear.
it also did help the weight distribution, I read that in some sites, thought you guys know the pros
weight distribution, sikit shj... anyway as to why its placed on one side, easy..
i)space saving (real awkward in the middle)
ii)cable saving (shorter cable used = less money spent on cables!)
iii)practicality (best spot id probably in the spare tyre well if it fits, lower + centre but.... comeon i think im the only idiot traveling with no spare)
not only you, I am wondering why I need a spare tyre..
since my pcd is totally different.
spare is 4 holes while current is 5 holes.
any idea which spare tyre can clear a 4 pot brake kit?
5 holes only.
Similar threads | |
