Airtrek parts.
darkcolt
16
1,503
Hi Guys, just a quick check if anyone is interested for Airtrek's parts. (MWTS)
Ralliart Din Meter (Full working condition),
Carbon Fiber Bonnet (need refurnish lacquer)
Brembo Brake Set front and rear (EVO)
EVO10 Rim w RE002 (75%-90%)
Yellow (brandname) Coilover
Mainly on accessories that will not affecting a running engine.
Though there are also boost controller, turbo timer...
In considering stage, not firm yet. Checking of interest first.
Swap + top up required and in Singapore workshop only.
stutzedward
3,416
561
Hi, I wanna know how to remove the airtrek roof rack. thanks guys.
If the roof is on your airtrek for years.... then very likely you can't unscrew it at all. I was told most of them need to grind off the cut cos they rusted. And also, you will need 2 strips costing around RM800 to cover the exposed groove.
Ss_Tuner
Oct 20, 2015
16
7
www.facebook.com
bro evo x is bbs or enkei?if bbs im interested.hihi
darkcolt
16
1,503
enkei
---------- Post added at 11:38 PM ---------- 6 hour anti-bump limit - Previous post was at 11:34 PM ----------
if arrangement is smooth likely. Example is taking my rim without the brake, I need to consider the swap rim can clear my brembo. Also taking the brake itself on an unmod airtrek, u need my knuckle and shaft(Evo7wagon) as well so it direct fit. My steering rack is EVO too. Best date is after Chinese new year.
---------- Post added at 11:39 PM ---------- 6 hour anti-bump limit - Previous post was at 11:38 PM ----------
The Bonnet with an air scoop lor, except it carbon fiber.
4gbanger
Jun 26, 2013
1,958
386
683
Johor/ShahAlam
enkei
for the CF bonnet, is it an aftermarket brand or local custom shop CF?
darkcolt
16
1,503
I don't know brand. But it definitely the early batch from the Singapore club with quality else by now it should have been wrapped under our high tune turbo condition. Only need re-lacquer.
The eighth generation of the Honda Accord has been given a minor facelift by Honda Malaysia to refresh its appeal in the market whilst building on all the features that has made it a bestseller in the country and neighbouring regions as well...
