advise on fuel pressure regulator setting
pac_jb
131
14
Hi bros,
I need advise in fpr setting for evo 3, im using walbro fuel pump with stock ecu n injectors, my foreman set the fpr to 3.5 bar with the vacumm line on, but car feels really heavy, and with aircond on its even worse, today I reduced the fpr to 2.9bar on idle with the vacumm line on. Any recommendation for ideal setting for the fpr. Tq
Have to check what is wrong? Too much fuel or too little fuel going in. You reduce the pressure so was it better? Reducing the pressure means less fuel forced in
pac_jb
131
14
After reducing the fuel pressure the car feel much lighter and more response , I set the pressure around 43.5psi @ 3bar without vacuum hose, so with the hose its around 2.6bar..
Since it is adjustable now, just try other settings and see how it works. Find the best that suits you.....
on scooby usually 2.7bar.....on evo3 not sure.....could be lower..could be higher
I've found that butt dyno like what you're doing now doesn't really work. In the past I adjusted mine to 4bar and that felt good. But on a dyno it showed the AFR too rich on the higher end and that caused my plugs to foul a lot faster. After dyno tuning the thing, it worked better overall at 3bar instead.
So best to get it dyno tuned la (at least a dyno with AFR readings)
Work better at 3bar, but butt feel good or not?......hahhahahhahah:rofl:
I don't recall to be honest. There was some slight knocking in the higher rev range I think. Resolved with 97 petrol
Means running richer fuel ratio no knocking, both ways also use more RM....hahaha:rofl:
I own a Saga Magma 8V and I just wanna find out from all the sifu here if my engine can support the compression made by the NOS boost??
