Running on 195/55R15. Most i go is 205/50r15 only. Not changing rims.
Also, lucas, pm for 205/50R15?
I'm running on 7.5 width rims.
Mine should be about that too. 195/55 and it doesnt look stretched.
Wah! 195/55 on 7.5", Mine 215/45 on 7" only....
Normally R15 rims width around 6.5-7.0. Unless you purposely find 7.5.
Yours not R15 rite? Before that was looking for R15 215/45 or 215/50. Not available in MY
Thinking back, I haven't actually measured the width of my tyres yet. Perhaps I should. I still have no idea what rims I'm on.
Other than the shop I know, anywhere else u guys know selling Michelin PP2? 165/55/14.
Already stop production but I know there are still stocks left.
Yup, most R15 are 6.5 or 7 only. Mine R17.....
---------- Post added at 09:38 AM ---------- 6 hour anti-bump limit - Previous post was at 09:36 AM ----------
Rim width brother as tyre is 195 means 195mm already. Take one wheel out and read the info on the back of the rims....
---------- Post added at 09:38 AM ---------- 6 hour anti-bump limit - Previous post was at 09:38 AM ----------
If old already no point as you will use another few years, then half way you will say rubber harden already....
Ya, was thinking about that too. Unless if normal driving then okay to use if price cheap. If less than 3 years old if not used wont be as hard as those used on the road for 3 years right?
Maybe 2 years old tyre then use for another 2 years.
Yup, if going to use 2 years plus, better get less then 2 years old. If 3 years even though not used, once on the road they start to age pretty fast. Harden rubber with plenty of threadwear balance, also no use....
Noted bro. Not to get more than 2 years old tyre. :top:
Unless want to burn it off for 1 track day haha!
Sunday was the only time I totally max out the limit of the PP2, screeching all the way up
But really good grip. Just too bad front one not much left.
Need to rotate liao....
Guys, does all Kumho tyres harden quickly like the KU36? I have a feeling I'm losing grip on my Ecsta's.
Bought in January. 8 months I guess? Not sure how long it sat in the tyre rack though.
Is it on the tyre itself? Would go and have a look on it later.
Best price? I have a feeling about that too.
If you are buying a tyre way cheaper than many other workshops. That's where u have to be careful.
I kena once before. Tyre cheap and + balancing but not including alignment. Fine, but I got con for installing those camber screw. Tyres RM90 a piece X 4 only RM360. Total I end up spending RM500.
If u see tyre cheap, just buy them but get the alignment done elsewhere. If u want to do it on the spot also can, but just reject offers like installing camber screw or anything.
Usually they offer such thing just cuz trying to compensate back the price they give on the tyres.
So, going other shops is better.
2nd reason, tyres are old which is why is cheap. Yes is on the tyre itself.
Please don't mistaken the 1st two numbers as the Month & Year.
Is 2nd Week of Year 2004 instead.
Similar threads | |
