How to install fd2r suspension to fd1
The answer is u only can swap the rear suspension setup only, the front absorber impossible to swap due to FD1 / FD2 lower arm & subframe is totally different with original FD2R.
u are totally correct bro......
Hi Yes_No,
Thanks for advice.
But now i already install to fd1 with some modification in front bracket.
Hope no issue with this :)
Hii, i wanna ask you how you did the front suspension swap?because i have the same issue with u. I have problem to use the fd2r suspension to my fd1. I have the fd2r engine installed in my fd1, just the front suspension that not yet install. I have the driveshaft, brembo kit and the suspension. what i miss?please, need help :D
