car overheating can't trace problem
abunawas
80
43
hi guys, my ride a Wira 4G15, lately have some overheating problems that i cant seem to find the cause.
it only happens after the car is run for more than 1 hour, fan everythign normal, then suddenly fan wont turn and temperature go up.
i have changed new radiator, new thermostat, new sensor switch, new radiator fan motor but problem still there. water pump also brand new high quality item.
engine is all stock standards carburatorr
any bro experience this before? the fan just wont turn after a certain period. i cant seem to find the problem.
engine seems ok all the while no makan miyak hitam
wiring?
need to open head?? :banghead::stupid:
---------- Post added at 03:51 PM ---------- 6 hour anti-bump limit - Previous post was at 03:50 PM ----------
fan relay problem?
sighhhhh
hope no need to open head gasket
abunawas
80
43
Running too Lean or Engine head warp?
how would those cause the fan not to turn after a certain period?
if head warp sure overheat oredy, no?
---------- Post added at 04:08 PM ---------- 6 hour anti-bump limit - Previous post was at 04:07 PM ----------
yes. but 1st try to check your thermosthat & the wiring......
happened to my kancil previously.
ok thanks. how u fix the kancil prob?
abunawas
80
43
ok.
i dont think head gasket problem becoz radiator always full, the expansion tank also same no problem.
also when i cruise on highway no traffic jam temp very good. just that the stupid fan not pusing :banghead:
jun_ng_1208
476
32
Cheras
ok.
Happened to my Myvi few weeks ago too...its due to the worn out motor for the radiator fan, changing the motor solve the problem :)
penagihdadih
117
17
Shah Alam
ok.
start engine and open radiator cap, if there are bubbles then the head gasket warp.
if everything okay with your cooling system then u need to check the fan system. try to change the relay switch first, afraid the relay is season and cant working when its heated. Iv problem with head lamp relay before, it will stop working after few hours of driving.
ixeo
4,788
3,080
KL, Malaysia
Worn out motor will still spin but slower? Air con not so cold?
abunawas
80
43
no bubbles. ok i check the relay switch.
my aircond very cold.
sukam05
9
3,003
...it also happen to my iswara...changed new fan/radiator,sensor switch...
...temporarily I just do direct fan....no choice...
..my foreman ask me to check sensor switch for radiator becoz different radiator, different sensor switch ...
hello fren..i'm new here..i'm looking for neo/gen2/waja with 1.8 turbo gdi/gsr..i really need ur opinion coz recently i found two gen2 with gdi and gsr for sale..almost at the same price n year,so i really dont know which one to choose..which one is better?not only the power but mostly what will value for money (fc,spareparts,maintenance,etc)..please help me:adore: i'm noob..huhu
