I really need help, like seriously dude.
to be honest - all this "stage" stuff is bullshit. Got money, go all the way. Not enough money, do whatever your money can take you.
PNP, Stroke, Cams, Fueling, ECU, Exhaust and then all other things like dry sump, electric water pump, straight cut gear box, etc.
cvkit17
2,884
1,354
Agree. Why wana limit yourself to stages? Get the $$, think of mods that suits your driving style, then go for it. Plenty of modification parts out there you can do. If you like going S, then upgrade ur handling and braking. If you like going l, then upgrade your engine n braking. Btw, drive responsibly :wavey:
pwhyze
924
356
1,563
The only 'stages' in modding is how much money you have. Stage 1 would be <1k, Stage 2 is 1k~3k,etc2...haha
mADmAN
1,840
547
agree with izso... all this stage crap is just some marketing bullshit....
when modding u need to determine wats ur target first.. wat u want... etc etc
then go the best route (according to ur budget) towards reaching that target.
D7zul
2,697
848
Shah Alam
stages? like in Initial D stage? :biggrin:
u can make your own stage..
for me :
stage 1 = outside engine item such as air filter, extractor, exhaust, crank pulley, etc
stage 2 = inside the head item such as cam pulley, camshaft, spring, oversize valve, port & polish , etc
stage 3 = all the expensive item such as stand alone ecu, stroker kit, etc
and in between all that u need to upgrade brakes, suspension and everything that support your handling :wink:
different people, different opinion on the stage..
but most important is MONEY$$$..
lots of money can get u to all the stages at 1 shot :biggrin:
spoon civic
403
36
terengganu
for me :
so up to u bro..more money have..more modification can be done...................:driver:
meg_omen
421
96
3,028
Home - Klang; O
suggestion...
Stage1 - PnP parts like open pod filter, spark plugs & cables, extractor, pulleys etc...
Stage2 - braking and handling upgrade...
Stage3 - cam, cam pulleys, port&polish, oversize piston, piggyback ecu... good if you're doing overhaul at the same time...
Advance - standalone ecu, stroker, higher than 280 cams, forge crank/piston/rod, ARP bolts etc..
you're the one who set all the stages according to the modification route you wanted...:smokin:
YYC
1,833
939
I have modified my puny Iswara, after all the effort and money thrown in, with some disastrous results in between, all bigger stock cars were still running faster than me, effortlessly. It was quite embarrassing for me. So I decided to cut loss and sell some parts and retain some mostly of handling and braking stuff, and got myself an additional bigger cc car. That more or less meet my need. Wife does not complain but I'm not rich so get to be sensible already.:smokin:
But modding is addictive hobby, I'm still itchy.:listen:
Hi guys,
I'm driving evo 3, using exedy standard clutch and plate, my clutch seems to be giving way now , more slippage, thinking of changing just the clutch to exedy 4puck/3puck racing clutch , and use back the my current clutch plate, as its just 6monthz old, is it ok if I just change the clutch?..tq
