Im going 2 convert my waja 1.6 to GDi turbo....
Eswarah149
Jul 15, 2012
11
Johor Bahru
im newbie to turbo world.....Im going 2 convert my waja 1.6 to GDi turbo....i gt money 2 buy gdi turbo frm halfcut....wat modification can du 2 upgrade 160hp to more hp....?
please help me :adore: cause i never seen the pix of GDI turbo mod......
budakkampungaje
317
Dengkil
Displacement, cc 1834
Engine model 4G93 GDI
Max.power (Net), kw(PS)/rpm 165 ps (121.36 kw) / 5500 rpm
Max.torque(Net), N*m(kg*m)/rpm 22.4 kg*m (219.67 N*m) / 3500 rpm
Power density 7.82
Engine type Serial 4 cylinder DOHC16 valve IC turbo
Engine information GDI
Fuel system Direct injection
Turbocharger Turbo with intercooler
Fuel type Unleaded premium gasoline
LEV system (Low emission vehicle) Yes
Compression ratio 10
Bore, mm 81
Stroke, mm 89
Final gear ratio
Fuel consumption at 10-15 modes, l/100km 7.6
Eswarah149
11
Johor Bahru
sowie jpj nvr approve....:confused:
---------- Post added at 01:50 PM ---------- 6 hour anti-bump limit - Previous post was at 01:48 PM ----------
Power density 7.82
Bore, mm 81
Stroke, mm 89
Final gear ratio
bro hw many hp can upgrade GDI Turbo
DLegend
Official Contributor
430
14
5,018
jayjaynyc.blogspot.com
Pls don't get the GDI... i know it's newer than the CM5A GSR, but you will regret later...
I was in the same situation as you 2 years ago... 160bhp vs 205bhp... so logically went with the GSR... loving it so far.
budakkampungaje
317
Dengkil
but its only on paper...but when dyno the hp will down bout 5-15%...yeah!!! buts it's true better you take the GSR stock hp is more then the GDI TURBO.....
E-CM5A-SNGF....Lancer,Mirage GSR
Engine model 4G93T (turbo)
Max.power (Net), kw(PS)/rpm 205 ps (150.78 kw) / 6000 rpm
Max.torque(Net), N*m(kg*m)/rpm 28.0 kg*m (274.59 N*m) / 3000 rpm
Power density 6.05
Engine information
Fuel system ECI-MULTI (electrically controlled gasoline injection)
LEV system (Low emission vehicle) No
Compression ratio 9
Bore, mm 81
Stroke, mm 89
Final gear ratio
Fuel consumption at 10-15 modes, l/100km 8.1
Zaid Zainuddin
From Facebook
Oct 4, 2010
42
6
508
www.facebook.com
imho, if you can find tuner for direct injection engines i say go for the gdi cos it has better technology for petrol engines.. maybe up the boost to 0.8bar you can already gain the same hp as the GSR and i'm confident you can gain same if not better hp than the GSR
Blackheart617
Jul 26, 2012
it depends on u...
if u looking for nice interior n cockpit, go for GDI coz their cockpit look same wit' evo 7.
but if u crazy wit' power n speed, pls don't hesitate take 1.8GSRT (4G93T)..i'm sure u'll love it..:biggrin:
Mytli4
May 2, 2012
9
Did anyone know that the half cut for gdi turbo is come CVT? Or is in 4AT speed?
In fact I actually consider to move for this engine as the price is more reasonable as compared to gsr .. Any comments on the parts and maintenance ?
peeche
395
165
Sin City, MY
only 2-3k cheaper. for god sake, the engines differ like sky and sea..
if you're converting your engine because of performance. please forget this GDI engine.
this is not a performance engine.
certain parts is hard to find.. nearly impossible.
performance upgrade parts.? no..
up boost? forget it.. kaboom (it uses direct injection.. if you're trying to fool the ecu increasing the boost.. then the direct injection will fool your money)
Mytli4
May 2, 2012
9
Thanks for the advice.. Then i will opt to gsr 4g93T .. Any recommendation workshop to go for transplant ? I need someone who is reliable and skills to do it ..
bros + sifus,
i wonder wheteher if we put on the evo bodykit on wira will the Traffic Police stop us and summons during roadbloacks..?
what about patrol car that pass by...?
any experience before..?
