recond is250 with gps,how to get MY map
yzliew
i got a unit of is250 high spec,mark levinson and come with gps and screen.
but may i know how to get download a malaysia map into this system??
it's only have uk map
Hi dude,
UK spec GPS run by dvd, Japan spec by HDD. Local spec also run by dvd, so what you can do is to get a copy of disc from local spec to try it out.
If you happen to get a copy of GPS disc from local spec lexus, pls share with me, hehe:biggrin::biggrin:
Hi dude,
And me also.. :D Lathen, meaning mostly Jap spec run by HDD?
if not mistaken, i think all run by HDD. Even if u got the disc, also have to find a way to install / overwrite it
Well, as far as I know, I can record songs into the HDD for mine. Didn't know the GPS is running on HDD too.. :)
I wonder who got the CD to overwrite/re-flash.. :) :adore:
In long run, I would suggest to install flyaudio. It's using Papago where you can download the map from malfreemaps. My map is dated 01/05/2011.
ed,
yes, i am using flyaudio. not bad and affordable, still can maintain the mark levinson and with additional functions like ipod integration, bluetooth phone, usb, video in etc..
how much u install flyaudio,i ask about rm4800 in setapak bubble motorsport
I've emailed to flyaudio dealer in malaysia,
They say flyaudio cannot work with Japan Spec, issit true?
Couldn't remember, it is around that price, excluding rear view camera, including bluetooth
---------- Post added at 08:08 PM ---------- 6 hour anti-bump limit - Previous post was at 08:06 PM ----------
I am not sure, if flyaudio Malaysia says so, then should be true.
My IS is bought from Lexus Malaysia, CBU from Japan, by right should be the same.
alvincbw,how about your gps?oem head unit needed GPS DVD to run or not?
how you update the map
yzliew, there is a MicroSD slot in flyaudio. You just download the latest map from malfreemaps and replace the map in the SD card. The latest map is dated 1st June 2011, you can download via My ASEAN Free GPS Map Project • Login . It's totally FOC and updated every month.
I can give you step by step guide on how to update the map in flyaudio if you need.
Em, there is no solution yet for uk spec, sad. Probably i will go kuchai lama find the sifu and help on this, hes good at bmw but hopefully can solve mine.
Alvin,
When you play cd audio can you still use your ML to play with it?
What about DVD? Using flyaudio?
Thanks
sorry long time never login to this forum. yzliew is right, you can update the map easily by just copy to the SD card.
---------- Post added at 03:34 PM ---------- 6 hour anti-bump limit - Previous post was at 03:27 PM ----------
Alvin,
Thanks
You are right.
You can still using the existing CD changer and ML to play the audio. For DVD you will be using Flyaudio.
Thanks for the info alvin,
I am have a recon UK Navi unit c/w UK map which are useless to us.
I called Lexus Damansara , they have the CD Map for Msia and Sg....but they are not selling it to Recon Units...WTH...!!!
Anyone knows the ppl inside Lexus that might able to help us ?
OMG , how about write an email to Lexus Japan , because all lexus also out from Lexus Japan there have right to provide and part for our car .
PS : i can't find email address LEXUS JAPAN
or need to find someone who bought lexus from lexus malaysia.
