- Mar 30, 2006
- 429
- 3
- 1,518
SOLD
Unichip Version A x 1 - installs on Proton, Mitsubishi, HondaB16A, HondaD16A, most Toyota, most Nissan
For Na can gain 10hp-15hp no additional harness needed, for Turbo and gain 15hp-30hp
Gain more power but save your petrol!!!
SOLD!!!, includes unit and harness hurry!!! Last unit! people dont usually sell these units after installation because of their desirable effects
What is Unichip?
Unichip is a piggyback device that is installed parrallel to ur original ecu. Unichip can then optimise efficiency of ur car petrol usage by extracting more power while using less petrol based on Air Fuel ratio. Usually on standard form... the manufacturers tunes the car to run a lil more petrol than needed both when reving and idling is to reduce heat and making it less prone for errors and part failures.... unichip makes it possible to tune ur car to maximise the use of ur petrol and maxise power and better throttle response at the same time by using proper tuning techiniques that does not damage ur engine or components
Results are instant and are immediately PROVEN on paper by the tuner....... and installation and tuning is once off too!! that means running cost will be reduced... also good thing is that the unichip fits on almoost all cars therefore when selling ur vehicle... its ez to sell or reinstall to ur new car....
I only sell the unit i dont do tuning... however if u need it installed and tuning it can be done by RS impressive (RS Impressive Motorworks) or call turbo lim, his number can be obtained on the website. he has great experience in installing and tuning unichips.
some people recommend emanage over unichip... but read ALL post in the link to give u a better idea which is better... there is no better.. but unichip does have more functions results depends on the tuner
http://www.zerotohundred.com/newforu...-manage-3.html
For more information please contact me thru PM or post here!
check out these review links also for further information
http://www.autotechengineering.com.a...U Tuning.htm
UniChip - Equipment Tests - Overlander 4WD Magazine - Australia's leading four wheel drive magazine
Max Auto 2.3 - Performance FAQ's - What is an Unichip?
Unichip tuners, performance chip tuning, conversions
Contact : 012-3333431 Andy
[email protected]
RS IMPRESSIVE MOTORWORKS SDN. BHD. (656247-H)
25, Jalan Ind. PBP 10,
Taman Industri Pusat Bandar Puchong,
47100 Puchong Selangor.
Tel: 03-58911773
Fax: 03-58911770
Mobile: 019-3309426 (Turbo Lim) / 019-2240612 (Jocelyn)
What is Unichip?
[email protected]
Tel: 03-58911773
Fax: 03-58911770
