- Mar 29, 2006
- 939
- 2
- 1,518
Item(s):
The P3 12" subwoofers are very popular, especially with people running multiple subwoofer configurations. Their dual voice coil design gives many different wiring options to ensure you get the most from your amplifier.
Rockford Fosgate Punch P3D412
12" Dual 4 ohm Punch Stage 3 Subwoofer
General Features:
12" Dual 4 Ohm Rockford Fosgate Punch Series Subwoofer
Power Handling:
Peak: 1000 watts
RMS: 500 watts
Impedance: Dual 4 ohm
Kevlar Fiber reinforced semi-pressed paper cone
High excursion Poly-ether-ester surround
ABS/Acrylic dustcap assembly
Tear and fatigue resistant poly-cotton dual linear spider
Embedded 16AWG tinsel leads
Venturi-Effect cooling increases air speed across key thermal components of the speakers motor parts to maximize cooling
Reverse mountable subwoofer with reversible diamond cut cast aluminum trim ring
Tall profile surround allows maximum linear travel without reducing overall piston size
Extended pole piece and bumped backplate
2.5" High temp 4-layer voice coil with spun-laced Nomex® reinforced collar
Anodized aluminum voice coil former quickly dissipates thermal build-up on the voice coil
102 oz. double stacked ferrite magnets
Protective PVC textured magnet cover
Dual 10AWG compression speaker connectors
Frequency response: 27-250 Hz
Sensitivity: 85 dB
CEA-2031 Compliant
Price: RM 588.00
Dealing method: COD or Post via Courier Service add RM 50.00
Location of seller: Pandan Indah / TESCO Ampang
Contact method/details: PM/SMS/CALL 012-2520922
Age of item:
Condition ok. Used around 1-2 years. Can Crazy Punch if you like SPL sound...!!!
Picture:
Reference's: Rockford Fosgate Punch P3D412
General Features:
Power Handling:
Peak: 1000 watts
RMS: 500 watts
Sensitivity: 85 dB
CEA-2031 Compliant
Price: RM 588.00
Age of item:
Picture:
