[WTS] Perodua Kenari Aero (M) 2005 - 1st Owner/Acc-Free/Tip-Top Cond.
SOLD
Item(s):
PERODUA KENARI AERO (MANUAL TRANSMISSION) registered March 2005 (FULLY SETTLED, no loan attachments)
1st Owner / Accident Free / Tip-Top Condition and Well Maintained / Full engine overhaul done in Dec 2012 - by reputable workshop (maddriver), backed by 3 years warranty against oil leak and oil burns
Pristine mileage:
- mixture of 50% city and 50% highway plus occasional spirited driving style - 12.9 KM per litre fuel (RON 95)
- mixture of 25% city and 75% highway and casual mode, no spirited driving - 14.3 KM per litre fuel (RON 95)
Package includes:
All-Inclusive of what comes with the car as well as all the goodies listed below:
Stabiliser bar - UltraRacing Four-point Front Strut Bar / Front Tower Bar / Code: UR-TW4-016
Stabiliser bar - UltraRacing 19mm solid Rear Anti-roll Bar / Rear Sway Bar / Rear Stabilizer Bar / Code: UR-AR19-069
Car Rims - Volk Racing CE28 x 4 (14 inch x 5.5 inch) TAIWAN REPLICA Bronze Rims
- standard security nuts x 16 (star-shaped allen key)
- steel air caps
Extractor (installed at Speedworks) - Hot Bits 3-1 Extractor for Kenari 1.0 (HB.EM 85-201-S)
- All pipes are equal lengths and mandrel bent.
- Dyno-tuned for maximum engine power gains.
- Bolt-on directly to the corresponding Hot Bits Exhaust System.
Exhaust (installed at Speedworks) - Hot Bits fullset (Front and Rear) performance exhaust setup for Kenari 1.0, 2 inch piping (HB.ES 85-400F & HB.ES 85-400R)
-All mandrel bends for maximum gas flow with-out any restrictions.
-Low-note sporty exhaust sound, maximum sound level 78 decibels. Aluminised steel pipes and mufflers Dyno-tuned for maximum engine power gains.
-Direct bolt-on exhaust system to the corresponding Hot Bits extractors.
Car Mats (installed at EA Autoworks by Howie Choo)
- New custom-cut Light Brown Thick Wire Coil Car Mat (the original mats are still with the car until today, they are underneath the Wire Coil Mats)
Audio - Eclipse CD2000 Head Unit: User Manual
Audio - JBL 6.5 inch Mid x 2
Audio - JBL 1 inch Tweeter x 2
Audio - JBL 10 inch Sub-Woofer x 1 with custom box
Audio - Dominations RS (4 Channel Amp) x 1
Audio - SoundStream crossover cables
***All Audio components and wiring installed at EA Autoworks by Howie Choo***
Car Regular Service Rounds (12/08/2013) - 3rd service round after overhaul:
- Engine oil (5w30)
- oil filter
Car Battery (05/08/2013) - TRANE Silver Calcium SMF (106H60L SMF): Rated 5 Star battery
Front Brake Pads (15/01/2013) - Sumitomo pads
Steering Rack Replacement (17/04/2013)
- Reconditioned: comes with 6 months warranty
Car Tyres (23/03/2013) - 4 x KUMHO KU31: 165/55R14 (90% thread - immaculate condition)
Full Car Overhaul (21/12/2012) - Complete process which includes the below items:
- Con rod & main bearings (Std)
- Piston and Rings (050)
- Water pump
- Clutch set
- Timing belt, aux belts
- full overhaul kit
- lcp
- valves and guides
- all fluids and guides
- a/c oil and gas
- engineering works (engine balancing)
Car Absorbers & Springs (22/10/2012) - Complete GAB Semi-adjustable Front / Rear Suspension and Coil Springs:
- 1 set GAB SL SERIES SUSPENSION (U-TYPE)
- 2 x GAB ADJUSTABLE COIL SPRING - 200/4K/65
- 2 x GAB SPORT SPRING (REAR)
- 2 x GAB KENARI ADJUST KIT (REAR)
***installed and setup at RSOne Motor Sport Kepong***
Price: SOLD
Warranty: AS-IS with the below:
- transferrable 3 years overhauled engine warranty (on one condition: all subsequent car services MUST be performed at the same workshop that did the overhaul)
- 12 month warranty for car battery from the date of purchase as per mentioned above
- 6 months warranty for reconditioned steering rack from the date of purchase as per mentioned above
- 12 months warranty for Dominations RS Amp from the date of purchase as per mentioned above
- 12 months warranty for GAB suspensions from the date of purchase as per mentioned above
Dealing method: CASH PREFERRED (buyer pays for the transfer fees), loan - buyer's own arrangement with deposit and indemnity letter agreement
Location of seller: KL, Kepong, Selayang
Contact method/details: PM/Call to discuss further.
Age of item: registered in March 2004
Item(s) conditions: 1st Owner / Accident Free / Tip-Top Condition and Well Maintained / Full engine overhaul done in Dec 2012 - by reputable workshop (maddriver), backed by 3 years warranty against oil leak and oil burns
Picture:
Picture links
Reason for sale: Need Cash and would like to seek for another lovin' and caring owner to take care of this great car
Thanks for viewing! :wavey:
SOLD
Item(s):
Pristine mileage:
Package includes:
- steel air caps
- Engine oil (5w30)
- oil filter
- Water pump
- Clutch set
- full overhaul kit
- lcp
- valves and guides
- a/c oil and gas
Price: SOLD
Picture:
Picture links
