The world’s most advanced and versatile battery charger, maintainer and tester
Recover batteries thought to be at the end of their lifespan. The most common cause of weak or "dying" batteries is sulfation, where a sulfur content of the sulfuric acid (the electrolyte) forms a layer of sulfur on the lead plates of your battery. Using the desulfation charging method of Optimate 6, this layer is removed, reconditioning your battery to receive and hold charge.
Optimises battery power and life
Your battery is a hungry beast that is not fed enough power to keep it at its peak, due to all the other power hungry functions of modern automobiles. The charging and maintenance function of Optimate 6 keeps your battery at its optimum level of performance, giving your car electrical systems the power it needs to run at optimum as well.
Early warning of battery problems with Unique test and maintenance cycle
Optimate 6 is programmed with multiple tests for possible faults, which are run at intervals. The coloured indicators on Optimate 6 will show what faults are found, enabling you to take preemptive steps. You can also leave the charger connected indefinitely, as Optimate 6 will never overcharge your battery, thanks to the powerful Ampmatic processor.
Ampmatic current control: 0,4 – 5,0Amps
Optimate 6's unique Ampmatic processor is able to find the best way to charge your battery, automatically. Depending on the condition of your battery, it will run different charging processes in order to restore your battery.
Maximize your savings by maximizing your battery life
The longer your battery runs, the more you potentially save, especially if you have more than 1 car at home.
[YOUTUBE]6nG7NImplHU[/YOUTUBE]
Package includes:
1x Optimate 6 Ampmatic charger unit
1x TM-71 fused eyelet set, weather protected (if you wish to connect leads permanently to battery terminals)
1x TM-74 clamps set for bench charging (crocodile clamp)
1x Optimate 6 User Manual
Price:
RM460
Warranty:
7 days 1-to-1 warranty (manufacturing defects and faults).
3 years by manufacturer
Dealing method:
COD available at the following locations and times:
Anytime
Lunchtime (around 12pm to 2pm, weekdays)Subang:
USJ 19 (near the mall), USJ 4 (Petronas)
Shah Alam:
Seksyen 9 (near the IPPK)
Night (6pm onwards)Kuala Lumpur:
KL Sentral, KLCC.
(6-7pm)
Kuala Lumpur:
KL Sentral.
(After 9pm)
Subang:
SS15, Empire Shopping Gallery.
Klang:
Jalan Melawis, Eng Ann, Bukit Raja (Jusco area).
PM for details
