[WTS]Focal K2Power 165KRX2
ICE -In Car Entertainment
szmy
543
518
Item(s):Focal K2Power 165KRX2
Package includes: Used In BOX
Price: RM 3000
(Brand New RRP: USD 1299.99 http://www.crutchfield.com/S-xr3QuICI2Nq/p...r-165KRX2.html)
Dealing method: COD
Location of seller: KL
Contact method/details: Call/Whatsapp/SMS- 017-3270723
Item(s) conditions: Item is used but in excellent 100% working condition
Item(s) features:
-component speaker system includes two 6-3/4" woofers, 2 tweeters, 2 external crossovers, and 2 woofer grilles
-K2 composite woofer cone (Aramid, foam, and glass fiber)
-butyl rubber surround
-2" woven Aramid fiber inverted-dome tweeter
-2-way external crossover with 3 tweeter levels, 2 tweeter slopes, and 2 midrange level settings
-2-ohm impedance
-power range: 6-100 watts RMS (200 watts peak power)
-frequency response: 70-20,000 Hz
-sensitivity: 93 dB @ 2.83 V
-mounting depth: 3-1/16"
Item(s) description:
The K2 Power 165KRX2 6-3/4" component speaker system bears the hallmarks of Focal's "Power Hi-Fi" philosophy. Nimble woofers made from Aramid and glass fibers demonstrate the control needed to reproduce delicate classical passages, yet they'll handle the power needed to drive your bass-heavy music with authority. The sturdy zinc-aluminum alloy baskets are non-magnetic so they won't interfere with the speaker's own electronics. And this 2-ohm system extracts maximum power from your stereo or amp so you'll get a little more punch from your system.
Focal's 2" inverted dome tweeters act like little woofers, dispersing the highs in a wide pattern to create an exceptionally natural soundstage. K2 Power crossovers use hand-made components developed by Focal to deliver an ideal blend of the highs and lows for a dynamic stereo image. The 165KRX2's crossover features three levels of tweeter control, a tweeter "slope softening" selector, and two levels of midrange control so you can dial in the sound to your car's environment.
Important Note: These Focal K2 Power speakers use a low impedance design to pull more power safely from your car stereo or amplifier. This design is compatible with virtually all factory and aftermarket stereos. Focal describes this model as a 6-1/2" speaker. Most manufacturers designate this same frame size as a 6-3/4" speaker. For simplicity's sake we list it as a 6-3/4" speaker.
Picture:
Reason for sale: Pencen ICE
Nowadays, I myself do not know what has happened to the people in the world.
The country itself is bad enough and yet we are unable to unite with each other.
We all have heard, watch and even some did experience road violence or some would call
it road bully.
Due to lot of reasons and possibilities that could have started that fight or rage on the road.
Guys, do remember this video that was recorded due to a minor accident which end up
in a big issue and a big fight till it was so...
