ahlai
Kenwood KAC8104D Monoblock Amplifier For SALE!!! [/B]
Used, all in good working condition.
High powered subwoofer applications tend to generate plenty of heat to the amplifier powering them. Music can only be enjoyed when an amplifier is on, and when an amplifier reaches high temperatures it will usually shut off to protect from it damage. The Kenwood KAC-8104D has built-in self-activating fans to protect from high temperatures so your system can play longer without having forced intermissions. That means even under stressful conditions, the built in fans will aid the heatsink to effectively cool the amplifier.
With an impressive output rating of 300 watts RMS x 1 Channel at 4 Ohms, and 500 watts RMS x 1 Channel at 2 Ohms, this amplifier is CEA-2006 compliant so all wattage specifications are true to industry standard. Combined with their total efficiency and high power output, the Kenwood KAC-8104D is the perfect option for any compatible subwoofer application!
Class D Monoblock Car Amplifier
RMS Power Rating:
4 ohms: 300 watts x 1 chan.
2 ohms: 500 watts x 1 chan.
Max power output: 1000 watts x 1 chan.
MOSFET power supply
LED power indicator
Tuned Bass EQ (0-18 dB bass boost at 40 Hz)
Speaker-level inputs with signal sensing for automatic turn-on
Preamp RCA outputs
Short circuit, DC offset, overload, and thermal protection circuitry
Aluminum die cast heat sink
Built-in cooling fan
Gold-plated RCA level inputs
Gold-plated screw terminals
Variable low-pass filter (50-200 Hz, 24 dB/octave)
CEA-2006 compliant amplifier
Frequency response: 5-200 Hz
Dimensions: 11"L x 2-5/16"H x 9-3/8"D
Sell at RM450.00
Reason for sell: upgrade
Call/sms 012-7704204 (Ahlai)
COD location :- Tampoi, JB town, Ayer Keroh & Malacca Town
RMS Power Rating:
MOSFET power supply
LED power indicator
Preamp RCA outputs
Sell at RM450.00
