Just wanna ask
What have to check and replace when doing full service~~?
What is ur car mileage?
All item must be check 1st before change:
1.check ur air filter
2.check ur spark plug
3.dust filter for air-cond(if u car got it)
4.check timing belt(every 60K or 100k for safety must done 8K before)
5.drive belt(i think should be 60k)
6.fuel filter
7.gear box oil(auto must be service frequently than manual)
8.brake pads/brake disc(check for burn marking and wear)
9.brake fluid and bleeding(must change every 2 years)
10.check parking brake(need to tight the cable back due too lose)
11.inspect for leaking at(cylinder head gasket,oil sump,gearbox,rear axle,radiator)
12.check rubber boot at ur suspension system(tie rod,lower arm,upper arm)
13.check engine/transmission mounting for crack
14.t/b check and clean if needed
15.oil filter,engine oil
16.check coolant,power steering fluid(just topping water/oil)
17.check the battery if you use regular battery(clean the terminal with warm water/must remove from engine compartment)
18.check tyre thread for wear(TWI)
19.spare tyre pressure check
20.air-cond system check
21.electrical check(headlamp,signal,brake light,3rd brake light,fog lamp,interior light,horn,alarm)
This is a kind of thing that should be inspect from my side..
