WORKS ENGINEERING ATF COOLER KIT.
The key to automatic transmission life is keeping the fluid fresh, clean and cool, when fluid temperature exceed the optimun operating range of 160'F to 200'F it begins to break down, decreasing the life of the fluid and in turn the life of the seals, bearings and all moving parts.
The No.1 cause of auto transmission failure is overheat ATF. Today's car generate extremely high under-the-hood temperatures, add to that heat generate by an auto transmission and you'll see why adding an auxiliary Auto Transmission Oil Cooler is a must for guarding against costly transmission repair.
Installation of WORKS Engineering ATF Oil Cooler Kit will reduce your oil temperature as much as 60 degree, which will help prevent transmission burnout and extend the life of transmission.
The bar and plate cooler construction result in an inherently strong cooler core of high thermal initial, at 30% smaller in size than conventional tube and fin design, WORKS Engineering Cooler core technology occupies lesser installation space and greater heat exchange.
Bakuso Racing Sdn. Bhd.
No.21, Jln PJS 11/24,
Bdr Sunway.
47500 Subang Jaya.
Operation Hours: Mon~Sat 9am~7pm
GPS: Latitude 3.067118, Longitude 101.601951
Click Here For Google MAP Location
Land Mark:
Same row with Kedai Tayar Silverstone Teck Meng, REV PERFORMANCE, Millennium, 2 shops beside SAMURAI RACING.
For serious buyer please Whatsapp or SMS
Desmond 017-396 8567
Email us : [email protected]
Dealing method : Pos/Courier everywhere in
Malaysia including Sabah, Sarawak, Brunei, Indonesia, Thailand, Singapore and all area in Asian.
Bdr Sunway.
47500 Subang Jaya.
Land Mark:
