Wira faulty oil pump
sanekit
Dec 9, 2015
1,616
157
663
Not so easy leh! To test all by hand for movement, you still need to rotate the crank shaft until piston is right on top so that valves are completely closed for tappets to have free play. While piston are down or midway the tappets are pushing onto the valves so they will be tight....lol
forgot about that. hahahaha! he can at least check the one that is closed. :driver:
alcyon
800
153
543
Err, why not ask mechanic to hook up an oil pressure gauge to the sender hole.
If you get nearly 90psi on cold start then not oil pump problem.
15,390
1) Okay. I'll open the valve cover and check it out.
2) Adjust and tighten, hmmm. Not sure how to do that, but I could google. Is there anything you would like to tell me about adjusting the tappets all by myself? Anything that I should be aware of so that nothing crazy can happen?
Ive never done that nor open the valve cover before. I always diy service my car, and alot more things, but never till open the engine cover.
3) Castrol magnatec 10W40. :driver:
The valve cover/rocker cover is held down by 12 x 10mm bolts, don't over torque then when putting them back in. They are quite fragile and you need to screw them back in opposing directions otherwise you'll get uneven lock down pressure. You might as well replace the rocker cover gasket too. RM10-15 only
If you don't know how to adjust your tappets don't do it. Pay someone RM10 to do it for you.
And lastly stop using magnatec already. Use something else.
30,002
People read their advertisement the oil can clink on the cylinder wall mah.......hhahhahahah:driver:
STR
155
18
Yeah, will try that before starting to do any sort of engine job.
STR
155
18
I just did tappet adjustments. Parked my car for around 3-4 hours. Started the car and the metal clanking noise is still there...
STR
155
18
Anything odd when you drive the car? or just the metal grinding noise when starting up?
Hmmm, nothing odd I guess. Sometimes there's some weird noise when stepping on the throttle (not sure how to explain that), which only happens once in a while. It's not a metal grinding noise though. So guess it's just the metal grinding noise when start the car.
30,002
If noise goes away after warmed up, I think nothing to worry about. If noise always there then you have a problem.....lol
STR
155
18
True enough, but I don't like the noise being there. I would want to fix it. It's annoying.
7,514
thats not oil pump problem la...just open valve cover and check valve clearance/ rocker arm condition enuf already...
if oil pump problem the engine jammed for good already
30,002
Yup, agree. Ask my mechanic before because friend's car oil pressure light came on. He mentioned for this case is the sensor fault, because if oil pump fail, the engine will jam in a few minutes.....:smokin:
A Post Every 5 Mins
There’s a glint of sun shine followed by a gentle breeze billowing through the curtains into my room. A whiff of sea breeze. I open my eyes and watch the ceiling fan slowly spinning. There are many reasons to smile especially since I’m here in Langkawi, thanks to Volkswagen Group Malaysia (VGM) who have flown us here for the launch of the 1.6 Polo Sedan. It...
