Hi sifu, any idea on this? Means my ABS system faulty or something wrong with my car? Btw, my ride is 2012 Exora Bold CFE...
Did you check the brake oil level? Check to see if the connector at the master cylinder is properly connected. Loosen connectors is common in Protons.
If all is ok, just bring it back to Proton for warranty. If no warranty go to a mech for diagnosis. If not mistaken, ABS will only trigger if you're at 90km/h and above when you jam brake.
Thanks all the advice given.
1. Will check on the brake fluid level and also the connector
2. Try to test the e-brake after work
3. If anything wrong, then is time to 'burn money'...
no la...kick in when there is uneven rotation if not mistaken. 50kmh can skid already if the floor is wet
2 years only, not covered by warranty?
Its the ABS sensor.
No need to check,same problem with the bold in my family.
Already claim twice.
If not mistaken its the sensor at the front.
its covered by the warranty.
and...in my casr.no labour charge.
Its the ABS sensor.
Thanks for the info bro... can I go to authorized WS to settle this or must have to go to CS?
---------- Post added at 09:02 PM ---------- 6 hour anti-bump limit - Previous post was at 09:01 PM ----------
Sorry, I mean SC... blur edy...
Before you do, check for loose connections. Sometimes a simple solution will save a lot of time with SC
just go to sc and claim.
the sensor itself is faulty.probably not up to quality.however only few are affected.guess they improved the sensor then.
fyi the bold at my house is one of the earlier batch.
i prefer sc as authorised sc wont carry part most of the time.bigger sc have chance that they might have stock.if not just ask them to order.should arrive within a week.
dont worry,normal brake is still functioning as usual.only abs is not available.
Just went to SC and bingo, no stock and need to wait for it... now driving like:slug:
No worries bro..just drive like normal. Use the conventional Aku Brek Sendiri and drive cautiously
Old cars got no ABS and many survived that era so no problem haha. So did they tell you what is the problem?
Is the abs indicator light-up together with the handbrake lamp? (Even after u fully-release the handbrake). if yes, u need to scan your ECU to find the problem. If only the abs light on, most probably the sensor is dirty. The sensor is not easily fault. It actually a magnet which will collect any "metal dust" around it and finally fully covered the surface and make it unable to collect enough signal for ecu. Drive around after u cleaned it then the light will go off once ECU receive a correct signal from the sensor.
