which one is ecu???
niakulah
im using cd6 h22a, just changed to manual gearbox... im confusing... the small one is the ecu too??? look at the picture.. and why after change to manual gearbox auto cruise not working??
how to switch of the d4 light in speedometer.. its coming blink,. blink.. blink... any effect??
i think as for the d4 light on the speedo, the easiest way is to remove the bulbs... as for ur other questions, i have no idea. u should consult ur foremen.
:biggrin:no foreman expert about ecu at my location.. before i go to find the truth formen ( so far) let discuss with member forum.. maybe it can be help for me.. save budget... maybe.. i know how many expert out there...:banghead:
easy way for you to learn, look for OBD pinout schematics.
There's only three of them, OBD-0 for pre 92' cars, OBD-1 for pre 96' cars, OBD 2a/b for 96 and up.
Once you recognise the pinout, whichever box matches the pinout is the ECU.
I have absolutely no clue about H22A ECUs so can't help you with that. P08/P30/P27/etc, boleh la.
H22a Cd6, is P0E/P0F/P0A.
D4 blinking might be due to the TCU throwing codes.
pull the codes.
as for the autocruise not working, there might something wrong with the auto cruise module/vacuum.
harlo fren and sifus,
cd6 h22a,... from auto, change to manual,...
the d4 blinking? ori auto u use tranny control unit (TCU),...
but after change to manual,... no more TCU in use,...
i'm not sure if ur ECU will throw codes to the d4,... weird.
anyway,... ur d4 and other gear indicators no longer in use,... u can mod vtec lite, etc on those lites, huhuhu!!!
join me and bien in myhavoc.net
some trgenganu sifus are there,... they can also troubleshoot ur cd6,... eh,... and if ur cd6 is jdm with rear wiper,... we straightaway give u otai status,... :idea:
i was know about the ecu in the picture.. the small one is ecu for auto gearbox.. just pull out... im using standard accord with minimal mod of engin only, no rear viper.. only have front viper... side viper also dont have..
hehe,... local cd6,...
A thread every 60 seconds
