Which Engine Oil for Ur B or H Series? And why?
AD_EG
6,000 RPM
6,328
231
Ipoh
Bro's please share what is your favorite or best engine oil used or using for your B or H series.
If,can share why also.
i was using M7 Semi Syn 10w-40 for my b series,i found that the engine felt lighter,revs felt light..but have to top up often...i dont have a bad seal and i am not burning oil.
Now i wanna look for alternatives,maybe Royal purple or Motul...300v i cant afford...trying to see how much Motul synergie 6100 costs..i know turbolight is around rm145 4L.
just wanna get some of the inputs from sifu's to maybe look at other alternatives...thanks bro's.
mark_15
250
torco is a very good lubricant also.....my ex sponsor...
redline lubricant also very very good..my current sponsor....
redline there is 2 type...1 is the normal lubricant like those motul,torco n bla bla...4 street use..
but i m using the fully RACE OIL REDLINE..the best oil so far i tested...
been put under high pressure/stress during dyno 4 3 hrs but oil still ok n the temp of the oil still maintain..n when use 4 my race also..oil give the best protection 4 my car....compare 2 all other brand...n very smooth on the rev..
AD_EG
6,000 RPM
6,328
231
Ipoh
hmmm interesting ...Redline racing engine oil around rm260++ for 4L right?
pencalat
805
19
JB
walaneh.... can't afford ma... just using Castrol semi / VtecLev semi on my hcomp engine..
bien335
1,834
48
1,648
Johor Bahru
one of my H22a is using VTEC LEV semi synthetic, the higher comp H22a is running ENEOS Fully Synthetic.
my K24a is also running ENEOS.
You cant realyl know which oil is the best, because if you do, then you have done metallurgical studies on the pistons, piston rings, cylinder liners which require destructive testing (cutting up the piston, examining the microstructure etc.. I can go on and on)
Rule of thumb, stick to the recommended oil grade by the car manufcturer.
Dont go and listen to some dumbfuck who says his 6A12 Turbo is using Seri Murni Pemeringkatan Dua Kali as engine oil.
tecque
727
7
sbn
I just started to use SpeedMaster 10 40 fully...rm165, so far dont need to top up.... But 5w30 motul Htech 100 need to top up more often....
clement
955
13
I'm running on Torco SR5 5-40 on my B-series
the Rev felt very light
Im running constant Hi rev (6000-9000RPM) at sepang and i dont have to top up oil
yesterday was my 3rd track day with the same engine oil on my car and i still dont have to top up but i gotta change d lah. haha
Ive tried Torco SR1 5-30 which is even lighter but its not suitable for constant Hi rev cos i need to top up the oil. But its suitable for normal drive. Very very light feeling.
so i still stick to SR5 5-40 so far the best(for me) ive tried
AD_EG
6,000 RPM
6,328
231
Ipoh
wah bro...thats around rm62+ per quart? rm248 for 4L...premium oil...
AD_EG
6,000 RPM
6,328
231
Ipoh
now im gonna try Royal purple 10w40...after that maybe ill try motul 6100
arrowhead
4,621
152
5,163
Damansara/PJ
I'm on motul turbolight 4100. So far so good. Why? Cuz it's recomended by 3 of my mechanics whom I have respect for. So it should be good enough for my usage.
AD_EG
6,000 RPM
6,328
231
Ipoh
quite a couple of ppl have told me about motul oil...some mentioned need to topup often also...your car is a weekend car...so might be a lil different.wont feel the pinch...hmmm need to survey see what othe ppl say...anyway keep the comments coming in guys..thanks for your input
arrowhead
4,621
152
5,163
Damansara/PJ
before it became a weekend car, it was my daily drive, of course not to work as i was not employed back then.
i drove around quite alot, i often travel to my workshop located in sri kembangan - easily 40-50km to and fro, and i visited them almost everyday for about 3 weeks because minor adjustments/tuning was needed. baru transplant maaaaa
so safe to say, my car was my daily drive for abit, before it became my weekend car. of course by daily drive i dont mean i drive it to work and do sales(travel like 150-200km PER DAY). but per day distance would be somewhere around 50kms or so.
never toped up the engine oil before. even now.
still not eligible ke?
kangyoon20
Over 10,000 RPM!
10,439
18
Malaysia
www.geocities.com
used 2 times honda lev fully and last week change to M7 semi on my half year old b16a
heard from SG foreman mostly recommend fully 5W40
used the lev feel ok, not much feeling..hehe
changed to M7 as recommended by the workshop recommended by AD_EG
price about the same for M7 semi wif lev fully
but did feel rev lighter
not sure long term high rev effect yet
hv to top up often? i din take back the remaining oil leh bro...T.T
AD_EG
6,000 RPM
6,328
231
Ipoh
in my case its different bro :biggrin: i go drags often,and i play non stop for around 2 hours,and i play on the road late at night,so i'm constantly "enjoying" my baby...so its only natural my oil should be topped up...M7 is seriously great,i have no regrets....so dont worry bro,you will be alright...my car abit different...:biggrin:
hows the cover? any sign of leaks? how is your idle?
oil you never take back? usually he will put in all 4 litres bro...anyway after 2k or 3k KM,check your oil,if you need a topup....just come over. :nurse: we will top up for you..when you say high rev,what figure are you looking at? cause 8k is considered normal for your engine...even if its on a daily basis you will be fine.
im trying to survey any alternative oil base on our forums feedback for their baby,then i will test it,and recommend to bro tiong for further feedback and see what he says...for now our best oil is M7..if dont find anything that performs close to this with a price tag less then M7,then we will be sticking with it..if we manage to find oil which performs like or better than M7,around the same price...we will start using that.
Now i am testing royal purple.feeling not as nice as M7,revs not as light,engine not as quiet also...but still acceptable...but not yet take it to pasir gudang...that day raining,track close.
---------- Post added at 02:32 AM ---------- Previous post was at 02:26 AM ----------
hehehe...ic ic.then maybe not that bad la...must try it out and see
kangyoon20
Over 10,000 RPM!
10,439
18
Malaysia
www.geocities.com
i never drag and track wif this car b4 la
haven got the chance and the car is not ready yet
once it is ready then it will be driven to its top ability..hehe
i still on standard ecu, daily drive to sch only less than 2km cant rev also haha
but when got chance surely i'll let it exercise a bit
the cover looks fine, no oil leak so far
will do the entire timing belt kit change this coming weekend
if got time then i'll bring my stuff to XH for change ok?
AD_EG
6,000 RPM
6,328
231
Ipoh
hehehe...no worries bro...a few more visits,and you will definitely be ready to test your baby.
good to hear about solved leaking issue...hope to see you soon :nurse:
A Post Every 5 Mins
Here are some pictures of the recent Bukit Tinggi time trial event catered to the supercars. These are just a fraction of the action-packed weekend. <b></b><b></b><b></b><b></b><b></b><b></b><b></b><b></b><b></b><b></b><b></b><b></b><b></b><b></b><b></b><b></b><b></b><b></b><b></b><b></b><b></b><b></b><b></b><b></b><b></b><b></b><b></b><b></b><b></b><b></b>...
