hey. just wondering. does anyone knows where to connect a vacuum gauge to a 4g13p carb iswara and put it inside the cabin? =)
what do i need?
what do i need?
bro..y dun u juz fix the wire under ur dashboard? it take a long wire to conect from engine bay fuse box le....rite? anyway...nice DIY...siawgu said:This is how i installed into my Kancil 850..
I use heater fuse as my ingnition (12v (+) )
Hope this help you..
DIY is the BEST ~
bro..sure can fit...a beter way to decorate ur interior look...hehe....Grim>>> said:can an efi engine put a vacumm meter???
not long actually.....huakenny said:bro..y dun u juz fix the wire under ur dashboard? it take a long wire to conect from engine bay fuse box le....rite? anyway...nice DIY...
bro, i use the fuse box below the dashboard not the engine bay... just the vacuum tube connected to the negine bay..huakenny said:bro..y dun u juz fix the wire under ur dashboard? it take a long wire to conect from engine bay fuse box le....rite? anyway...nice DIY...
I just bought an inline fuse holder and install it. I didn't use the fuse box. for the lighting part, there's some connection that you can get from the air con panel. if not, just connect it to battery (12V) too. for remote on, there's an acc wire in the cover with holes beside the fuse box (i'm assuming you're driving an iswara).hi bro, for the wire that connect to the fuse box there...
is it jus touch the connector den put in the fuse to fixed the vacuum wire into position? or got connect and tight it with any wire??
