water temp
theorekz
898
hiztorikal.c.t.
I just installed a Autogauge water temp gauge on my Iswara to replace the old 1(die already)...
then after some normal driving... i found that the needle is pointing between 90c n 100c...
is this optimum temprerature?
i scared wait rev some more my engine has to "enter factory"..
thx
ftzone
full throttle zone
5,339
141
3,163
Penang, Prai
www.ftzoneracing.com
for my car... turbo 4G93T showing max 90C when in traffice jam or 80C on full warmed up mode ... temperatures should not exceed boiling point (100C) below that.. it's fine.
ijoe
862
geng..aku punya meter temp pada panel pun dah sewel..bila aku tukar meter baru(2nd hand) pasal tacho aku kong..dia punya temp lebih dari separuh pulak...lagi suku nak sampai full...lain meter lain pulak prob....aku ingat nak tambah meter autogauge tu...err..ko pasang sendriri ke???pasang kat mana haa...kat dengan hose dari radiotor nak masuk ke engin tu ke??? ada pic tak?
tq...
ijoe
862
already bought & install autogage water temp into my car..need to replace the origanal water temp sensor coz actually the sensor have gone crazy...it sensse too much hot in my car...using original sensor with autogauge meter will mark the meter until 100-120 c. wahh so scared maa....now change to suplied autogauge sensor...reading mark on 80-90 c..one prob here...cannot use original wiring to panel meter...otherwise autogauge will not sense any reading...onli panel meter sense it...why....??
still waiting to install autogauge oil press...is it , it will cause same prob again...?
Does anybody knows where to get bump stops/rubber stopper for HWL MYVI coilovers?
Currently, im facing issues with tyre scraping fender for the rear part as my rims are wide with low offset and the rear coilovers are abit soft...
i've been advised to either roll fenders or install bump stop to prevent excessive movement of absorber.
If anyone here selling or knows a place where i can get them, do drop a reply here
Im located in KL/PJ
Many thanks in advance fellow petrol heads...
