waste water (acid i assumed)
IceBikers
62
3,008
Hello,
i parked my car in a complex mall and the car roof kena the waste water dripping from the pipe above. I only realised it on the next day and the white stain is there and hard to remove unless i use a coin cover with clothe n scratch it. it is not easy to remove!.
how should i get rid of it without hurting the car paint???
use wd-40? (i used b4 to remove left over sticker glue stains on car paint)
the worst thing is, it is not my car :sweat:
jombiee
950
13
Ghombau
waste water from treatment plant are toxic & corrosive, it will eat out your paint if you dont remove it soonest possible. If you cant remove it i think the damaged has been done.
frank118
435
24
The same thing happened to me but luckily i didnt leave it for long...it was hardened...i used car zippo lighter fluid just a little then car polish then wax...it was hell getting it out but it did.
Try that ICE..hope it works for you.
Tom
TIMETOATTACK
Jul 6, 2000
5,562
3,229
try some polishing compound or products that remove scratches
if you urgently need to return the car to a friend, you can try counting on the roadside car washes that offer polishing/waxing services to remove just that spot. make friends with them and they may even remove it for free
hope this helps
frank118
435
24
Tom is right...those guys would be able to help you out. Money shouldnt be an issue right now right. It would be costlier to lose a friend.
That's one of the reasons I never loan any of my babies to anyone...haha.
To all DIY expert or Sticker expert,
Recently, i had found the Carbon Fiber look's sticker, so i had think bout this idea!! Izzit possible for us to stick this kind of sticker to our whole bonnet, then spray several layer of Clearcoat paint on it?? So, the carbon fiber sticker won't be fade although we park under the hot sun, because it been protected by the clearcoat paint!!
But how can we stick the sticker to our bonnet perfectly?? Which means, no bubbles and all that?? So, the sticker...
