waja temperature
Sep 15, 2009
need help from other members..my waja year 2002 whenever reach evening time and almost night,after i switch on my headlight,especially high beam than the meter of the temperature will also follow rising..switch on the air cond and spot light,then the temperature will also keep rising but only for a while then the temperature will go down.......happen only during night not at day.help.......:confused:
mohd radzi
Re: waja temperature turun naik
danzEterna tq. very much for the answer....can you suggest me where can make that diagnostic check up? visit the sc or wiring workshop.thanks again bro...
hi i recently got a new project car a wira 1.5 manual in stock condition. i would like to add an oil cooler and gauges, oil pressure and oil temp.
can anyone recommend a good shop that can fix all this for me?
the oil cooler is maybe not needed for now, but i may change the engine later when budget allows, for now i just want the oil cooler and gauge.
i checked mudah , a lot selling the cooler and relocating kits from half cuts, but i am not sure if they will fit?
the 4G15 use...
