Im just wondering whats the max size of speaker i can mount onto waja front door panel? I wonder why Proton make something so fugly and yet prevent ppl from changing even just the speaker..
Originally posted by boeytan@Mar 25 2005, 08:38
if u willing to cut a bit on the power windows black plastic, 7" can go in, no problem.
[snapback]839090[/snapback]
if cut a hole at da plastic....would ur speaker wet up when raining....?
[snapback]839186[/snapback][/quote
of course u need to put something behing to prevent the water drip.. ask the installer do for u.
6.5" no need cut the door frame... just cut the power windows black plastic.Originally posted by kapitan@Mar 25 2005, 19:15
what is the problem with waja if wanna fit 6.5 inch??
issit the door panel or the door frame itself?
if cut the fugly grey colored plastic/pvc surrounding the speaker grill, then it should b okay i think.. dont think rain water will leak in.. but if door frame itself present the problem, it could lead to something else..
so problem 1 (door panel) or 2 (door frame)??
[snapback]840887[/snapback]
louis' door panel is awesome....... good job done....kudosOriginally posted by louis@Mar 25 2005, 22:14
just install a 7" to mine... but needs lot of work. it cost me 500 to install alone.
but with satisfaction.. very solid built metal plate built and screwed to the car metal frame.. weld additional metal ring weld to accomodate the speakers... with some angling.
but u hav to cut ur exsisting door panel.... as the mid will slant outward at the bottom.
installer = MEgasound
[snapback]841159[/snapback]
mail me the pics louis.. and i will post it up here ... B)Originally posted by louis@Mar 27 2005, 23:28
send me ur emails... i dont know how to reduce the pic size., and couldnt attached in to ZTH
[snapback]845286[/snapback]
neo79 said:You think Wajas one is bad? Till you see da Jazz... You'll bleed when they grind off the door frame to fit a 6.5"
