Vtec timing problems >> Need Views
pardypeople
803
5,018
Hi Guys,
A few days back I was late to work and eventually was doing some Vtec kicking on my way :biggrin: . What happen was, when I reached work I felt my timing not consistant which applies to both idealing and on the move. Now even on consistant speed, I get the jerk(fractional) feeling.What could be the possible problem? anything serious?
Kindly shed some light here...Thanks...Btw, I'm using a B18c gsr...
Thanks mates....
J101
1,304
malaysia
dying fuel pump - check fuel pressure
dying spark plugs - check spark plugs
loose ecu harness - pull and insert back
dirty IACV/throttlebody - clean them
dying distributor - check the coil and ignitor
clogged injectors - injector clean up
pardypeople
803
5,018
thanx J101...
Hi guys,
How many of you that own Protons, namely Satrias or Satria GTIs have had to change your wheel bearings before?
I am currently experience symptoms of worn out wheel bearings but whenever i send it to the shop there are no problems probably because the bearings haven't been heated up to where they start to display problems that i've been experiencing.
Problems:
Steering wheel judders when turning left on hard cornering.
Feels like the right front wheel is slightly loose...
