vios rear suspension problem
  • Thread starter dude7942
  • Start date
  • Replies 7
  • Views 6K
D
dude7942
Guest
hi.
i drive a toyota vios 2006 FL and just noticed problem with the rear suspension.
the problem is when i have 2 passengers at the back, the tyre will hit the side fender on uneven road and it only happened at the right side.
i'm still using stock spring and new absorbers at the rear.
from my visual inspection,i saw that the right rear side is a bit "toe-in" but at the left side seems ok.
can the rear toe be adjusted to its normal position?
hope anyone can advice me what can i do to settle this.
thanks..
usually the toe can be adjusted either front or rear.just go and asked allignment shop
okay...
i'll try to ask the alignment shop first..
but how do they adjust the toe?
i only seen they adjust chamber.
if nt mistaken i think vios rear suspension system is torsion beam n is fix,cannot be adjust like front...
normally redi got screw to let u adjust on stock car at rear side...but it depends on the rear suspension system design on ur car..sum design is fix n cannot be adjust..
i think mayb is other problem...
em,thanks for the reply.
agree with kian27 also..
vios rear suspension is torsion beam type,thus cannot be adjusted.. :'(
heard maybe need to be send for press using hidraulic machine..
so sad...
bao,ur car happen anything b4 ar?
if nt y will bcome like tat??
i dunno the history cause i buy the car second hand.
i'm not aware of it until i changed my rims :bawling:
now have to check with alignment shop and repair.
but no time right now..quite bz with works..
anyway,anyone can recommend me good shop around shah alam or puchong area for repairing?
thanks in advance..
any advice for me anymore?
i just checked with toyota and they asked to send the car tomorrow morning for further inspection.
sadly my car just finished warranty..
so sad..
Suggested post every 5mins
