Ultra Racing Strut Bar Review
satria_neo
Aug 1, 2011
47
9
508
Singapore
Hoho, today visit E Rev to install the Ultra Racing strut and 4 point lower brace bar.
I decide on Ultra racing after a long research and decide to go for a strong and rigid bar at the expense of weight (since its made of steel).
Sorry no photos since pics of the bar can be basically found all over the net.
After the installation, went to my favourite spot for testing (don't ask where).
Initial experience is not bad. I managed to squeeze out an extra 5KM/H on corners before my front begin to give way. Not bad investment since they are alot cheaper than brands like Cusco, better than Alutec etc (strut/brace bars are afterall just welded metal bars...don't need rocket science..).
60 -> 65Km/Hr.... not bad......
^pomen_GTR^
7,000 RPM
7,509
1,690
The Mines
well if add only certain bar not that heavy..my impression of UR bar (fender bar) is not that heavy actually from the looks....so it swept away my worry afterwards...
*a happy fender bar user :adore:
phibitis
761
www.mrkobe.blogspot.com
Does anyone know whether the old satria and the new satria neo uses the same fitting ?
Can i transfer my bars from my old satria to the new neo ?
Seeking for sincere advise ! =)
6UE5t
6,000 RPM
6,756
1,300
Was thinking to install also for my car but then many other who have tried in the same car said it's too stiff.
Not quite bro, there is some logic and 'science' to braces. You need to know where the chassis twists, how much tensile strength is needed to counteract that, whether stiffening that part of the car will have adverse effects to other parts of the car, etc.
It's not that simple! Copying from others isn't exactly easy either. How the bars are made and strengthened determine how it performs. I've seen a snapped off joint on a brace before (fake UR bar). The other scary things I've seen is the bar ripping off the bolts holding it down effectively damaging the thread and bending the chassis a bit.
So yes, it's not that simple although it's not quite rocket science.
Guys..i sprayed my stock rims...all for under rm40 only...check it out and give me ur opinion ok guys..i posted pics below
