- Nov 1, 2006
- 66
- 0
- 1,506
[youtube]LmwwsWmPhr4[/youtube]
[youtube]oWEib88_EF4[/youtube]
The secret which runs the circuit fast.
When it tries probably to put out the time with the circuit, the mostly person being able to delay the brake with penetration of the corner, becoming over speed, or disturbing behavior and returning the case which becomes slow is many, is, don't you think?.
As セオリー, being able to delay braking, when at as much as possible you lower speed short range, because the time when you open the accelerator increases it is connected to time rise. So, disturbing behavior with penetration of the corner, there is no origin or a child. Stabilizing the corner, running, you open the accelerator even a little quickly, speed with straight after the corner it is important to make high even with 1km/h. Because, because runs to run even a little fast, the method which passes through straight it is long is connected to time rise at the speed which is higher than the corner is.
For that, straight concern than corner. Stabilizing with slow in fast out, it is secret because the driving which keeps opening the accelerator quickly runs the circuit fast. When course 1000 of the Tsukuba circuit is taken as example, it becomes like below.
<< Travelling know-how which is in common to all circuit travelling >>
* Overstraining, thrusting, rather than disturbing attitude, it makes the car stabilize with the corner
* And, opening the accelerator, as quickly as possible to stand up, straight fast
* As for the corner, always you stand up independently even with continuation, the line taking of concern
* As for braking, as strongly as possible short
It stabilizes with the corner. Therefore シビック TYPE R is fast.
When セオリー which runs the circuit is known, as for シビック TYPE R seriously considering the time with the circuit clearly, it is found that it is the car which is set.
Because the extent where body rigidity is surprised is high, also the suspension rigidity is high, chassis system twists in cornering to be difficult to happen the roll is little. Therefore braking and, it stabilizes tremendously in cornering alignment change of suspension is difficult to occur, into the corner penetrates, it is.
Therefore, the accelerator can quickly be opened, it meaning that 4 wheels have considered the road surface as securely, also the catching of traction is good, can run straight fast. It is connected to the nature and time rise, it is.
If with you say, or even with the beginner person, do not do considerably big mistake many things do not rise with the corner, is the true place. Especially, if the short course like this course 1000 beginning and ending stabilizing, it can run. Don't you think? with the time which it stabilizes, it is the car which the running where the dispersion is little is easy to do.
Even with the Suzuka circuit, the speed which is not defeated to the large aerodynamic volume displacement car.
After test drive meeting when announcing シビック TYPE R was opened with the Suzuka circuit, there was an opportunity which rides in various ways with Suzuka, but it is fast in any case, is. This シビック TYPE R. One class and cover class are faster than the sport car above at the aerodynamic volume displacement, because it is. I was surprised to this.
It is such a fast car, but when you take in image, being to be even excessively smooth, being serious, it does not run, it is it is not, is? With you say. If so, you can hear the スキール sound of the tire and the sound of the engine, you think that it is recognized that it has attacked with full opening.
Being fast, pleasant car and シビック TYPE R. When also everyone by all means, designates this car as the hand, don't you think? as for one time we would like you to run the circuit.
