Toyota Prado Inclinometer
Praba8848
35
1,508
Penang
I own Toyota Prado Yr 98'. My inclinometer was not visible at day time as the internal lamination is almost shrink and it is fucntioniong well in night with lights. I decided to open up the device and wanted to check if I can replace the lamination piece. As I open the units and the front cover, the lamination was alomost drop into pieces and its like Tinted material which has shrink due to heat so I clean it away as it was on the surface of a mirror. I attached another layer of tinted film and fix it back. I turn it on the unit and only the light appeared but nothing else. I beleive the Tinted film which orginally attached has go to do something with display. I need help and advise me hot to solve my problem. Thanks
:banghead:
Dec 29, 2010
Kuching
Try Google "LCD & polarized film".
learn some thing,
Than suggest you look for some old LCD parts to use.
Praba8848
35
1,508
Penang
Thanks for all the Tips and I have find out that when I use my polarize Ray-Ban and look at it and I discover the images. I got a scrap LCD monitor and remove the piece and attach it. Now it works fine..Thanks
Oct 5, 2012
Subang Jaya
HI Praba, congratulations on solving the problem. I have exact same problem in a 98 Prado I just purchased. I have got the polarizing film from an old laptop... but how to remove the console to replace the film? I opened the top and removed what look like mounting screws but the console still firmly attached to the top of the dash!
Looks like Lamborghini’s tantalising teasing has come to an abrupt end with these leaked shots purportedly of the new Aventador LP700-4 that will lead the supercar-makers portfolio and take the baton from the outgoing Murcielago.
As Sant’Agata toyed with us by leaking teaser shots of details like the engine, transmission and rolling chassis, an allegedly scanned image from the upcoming issue of the...
