history of the MR2
The Toyota MR2 design process started in the mid 1970's culminating in the first prototype, the SA-X. In the early 80's the Toyota designer Seiichi Yamauchi was appointed head of planning for the Toyota MR2 project, the SV3. The original concept was for a small two seater commuter car, many different combinations of engine placement and drive were considered before the eventual mid-engine rear wheel drive set up was chosen. During the design phase engineers from Lotus where involved with Toyota on ride and handling characteristics for mid-engine cars but Lotus were not involved with the final production specification.
The Toyota MR2 was launched shortly afterwards, in June 1984. Named by Toyota from the initials from 'Midship Runabout 2 seater", this first generation has become known as the "AW" MR2.
The second generation Toyota MR2 (SW20) was an all new car. It retained the mid-engine, two-seat layout, but it was longer, wider, heavier, and more powerful. The distinctive angular styling was replaced by a softer more curvaceous style.
Toyota's Chief Engineer Tadashi Nakagawa knew that the next-generation sports car had to incorporate a high level balance of stability and agility, coupled with the pursuit of fun in driving.
However, it was also common knowledge that although, a long wheel base gave straight line stability, agility was reduced as cornering power was effected. The designer team headed by Tadashi Nakagawa recognized that weight reduction was the key.
The third generation Toyota MR2 , the MR2 Spyder or MR-S, energed in Japan in October 1999, followed by US/europe in 2000.
Toyota engineers have used the very latest technology to cut weight and boost performance. But it is in the area of agility that the mid engine and lightweight design really shines. The mid-engine design, combined with an ideal 'wheelbase to overall length' ratio, makes this one of the most nimble of vehicles on the road. Quick and accurate driver response is the name of the game for the new MR2 roadster. The MR2's 1.8-litre engine has VVT-i (Variable Valve Timing - intelligent) for maximum midrange torque and superb top-end power, with the best fuel consumption in its class
Spyder Factory japan
