Tomei Stage 2 ecu and Ralliart suspension for Evo 8
MonsterE6
27
Hi Guys,
I have a set of Fully adjustable white Ralliart suspension for sale to suit Evo 7,8,8.5 and 9. Adjustable low high and hard/soft 4 way front/back. Very comfortable and damping is excellent. Just took out of my Evo 8.
Asking for 2.8k ono
At the same time I have a Tomei Stage 2 reprogrammed ecu comes complete with 255 l/hr in tank pump needed for the ecu ( for Evo 8). This ecu removes 180km speed limiter, rev cut, fuel cut, revises ignition timing and fuel map. Guaranteed 360 ps on engine or dyno proven 310 at the wheels ( I have the dyno sheet) at 1.5 bar max with Tomei or HKS camshafts. There's no startup problems in the morning or idle problems with this ecu. Suits our Malaysian petrol. Instant power difference provided if you have full exhaust system, air filter and optional cams. Will run with or without cams. Standard evo hp is only 230 at the wheels,so its a 80 hp increase overall!!
Ecu ( exchange only) with fuel pump asking for RM 2700. ( only 3 months old) Ecu has a Tomei sticker badge for authenticity.
Please call 012-3166655 or PM me for details
leslie
2,946
230
5,163
i'm inrerested in your suspention.. how old is the item?
the ecu is for evo8 only ah? evo 7 canot fit meh?
MonsterE6
27
Hi,
My posts mentioned E7, E8, E8.5 and E9 all can. Ralliart has one part number for all the above. The suspension is about just over one years old. Still very good condion. Driven 13,000km only.. No oil leaks or anything...
DDgreystar
2,149
9
wow...ralliart suspension.....gud choice man !! :)
leslie
2,946
230
5,163
bro,
i mean the tomei ecu leh stage 2... i wondering if can it fit evo 7.. coz you mention (evo8)
just also wondering y are you changing? since its a good item!!
MonsterE6
27
Oh, ok... no la, Evo 7 cannot fit.. not the same apparently because the harness connector is already different. Evo 8.5 still ok.
silver_car
202
malaysia
bro is the ralliart suspension white in color? or is the bilstein made for ralliart one?
bro ada pictures to see? cheers
MonsterE6
27
The Ralliart suspension is white in color with red springs. Yellow Bilstein won't be this price. Pictures can but only through MMS. You can drop me your H/P ho. and I can send to you...
silver_car
202
malaysia
hey read about it in the ralliart webpage. very good suspension man.
why wanna sell? keep lah. unless u upgarde to more geng liao bro.
The new long wheelbase BMW 330Li M Sport arrives Malaysia. Lengthened by 110mm and heightened by 6mm, this is BMW Malaysia's first ever locally assembled stretched 3 series.
6.2 sec / 258hp / 400nm / 2L 4cyl turbo B48 / 8 speed automatic / RM300,800.00
BMW 330Li M Sport dimensions:
Length: 4,819mm (+110)
Wheelbase: 2,961mm (+110mm)
Height: 1,441mm (+6mm)
Apart from the 42mm extra rear...
