RACING PARTS (Picture file 1)
________________________________________
ELECTRONIC
1. HKS FCD BOOST CUT & RPM CUT FOR MIT VR4 EVO 123 (LIMITED EDITION) (RM 200)
2. HKS SLD SPEED CUT FOR MIT (RM 150)
3. HKS BOOST CONTROLLER (RM 400)
4. HKS PFC. F-CON COMPUTER BOX FOR MIT VR4 4G63 [wiring & map sensor full set] (RM 850)
5. HKS AIR FILTER BOX FOR MIT VR4 RS TURBO 4G63 (RM 150)
6. KNIGHT SPORTS FUEL CUT & BOOST CUT FOR MAZDA FC (13B) (RM 150)
7. EVO 123 WIRING & WATER SENSOR & AIR FLOW & INJECTOR 51OCC & TURBO SENSOR &
THROTTLE BODY SENSOR(RM 1100)
8. MIT 4G63 TURBO VR4 RS WIRING & AIR FLOW SENSOR (RM 600)
9. TOYOTA STARLET TURBO EP71 COMPUTER BOX (RM 300)
FUEL PUMP
1. NISSAN BIT FUEL PUMP (RM 100)
2. KNECHT RACING FUEL FILTER, GERMANY [NEW] (RM 50)
INJECTOR
1. DENSO INJECTOR EVO & VR4 510cc (RM 350)
RACING CLUTCH & FLYWHEEL
1. CUSCO RACING CLUTCH & PLATE FOR MIT EVO123 & VR4 & 4G93 [NEW] (RM 1400)
2. CLUTCH FOR MIT MIVEC & PERDANA & 1.8 WIRA japan ( ORI ) (RM 60)
SARD SILICONE HOSES
1. SARD THERMO WRAP 50mm, 10meters [NEW]MADE IN JAPAN (RM 300)
EXHAUST
2. JAPAN JASMA STAINLESS STEEL 3" FOR EVO & TURBO USE 90% NEW (RM 350)
3. JAPAN STAINLESS STEEL 2" FOR NA (RM 200)
4. VR4 EVO123 TURBO OUTLET V DOWN PIPE (RM 80)
5. DASH TURBO TCO5 TURBO ADAPTOR (RM 50)
6. STAINLESS STEEL CENTER MUFFTER 2½" (RM100)
7. HKS CENTER MUFFTER FOR EVO 7.8.9 90% NEW (RM300)
SPARK PLUG & CABLE
1.
2. VR4 TURBO RS PLUG CABLE (Original) (RM 100)
3. NGK PLUG 7EA FOR VR4 (RM 50)
4. SPLIT FIRE TRIPLE PLATINUM PLUG FOR VR4 (RM 80)
5. HKS F40RE PLUG FOR MAZDA FC & FD ROTARY ENGINE (RM 100)
6.WIRA PLUG CABLE 1.3 1.5 (ORI) (RM50)
7.VR4 PLUG COVER (ORI) (RM30)
8.VR4 RS IGNITION COIL (RM150)
9.EVO 123 DISTRIBUTOR (RM100)
10.SUPER TOURING DASH TURBO RACING PLUG CABLE (RM50)
SUSPENSION
1. TEIN HA ADJUSTABLE SOFT HARD & PILLOW BALL UPPER MOUNT FOR TOYOTA JZX 100 (F) (RM450)
2. TEIN ADJUSTABLE FOR NISSAN SKYLINE R32 (F) (RM 400)
3. EVO 7 ABSORBER FULL SET (F&R) [Original] (RM 800)
4. BLITZ V,IS SOFT HARD ABSORBER MAZDA RX7 FC3S & (R) (RM 250)
5. MIT 4G63 VR4 RS TURBO PILLOW BALL UPPER MOUNT (REAR) (RM 400)
6. PILLOW BALL UPPER MOUNT & LO HI FOR SUPER TOURING & ISWARA (F) (RM 450)
7. WIRA 1.31.5 SPORTS RACING SPRING (F) (RM 100)
8. EVO 3 (Original) spring (F) (RM 100)
9. FTO (Original) spring (F) (RM 100)
10. VR4 RS LOWER ARM & ANTI ROLL BAR (F) (RM 150)
11. R1 RACING ANTI ROLL BAR Bush [NEW] (RM 30)
12.MITSUBISHI GALANT VR4 RS TURBO (FRONT) CUSCO STRUT BAR (RM120)
BRAKE SYSTEM
1. SUMITOMO BRAKE PADS FOR CIVIC EG (F) [NEW] MADE IN JAPAN (RM100)
2. WIRA 1.5 DISC ROTOR & BRAKE PADS & CALIPER & KNUCKLE (F) (RM150)
3.MIT VR4 RS BRAKE HOSE (ORI) (F) (RM50
4.MIT SUPER TOURING DASH TURBO BRAKE HOSE (ORI) (F) (RM50)
5.WIRA BRAKE HOSE 1 SET (ORI) (F&R) (RM100)
6.MIT VR4 RS TURBO RACING BRAKE HOSE (FRONT) (RM100)
7.PROTON ISWARA RACING BRAKE HOSE (FRONT) (RM100)
8. EVO 123 & GSR ABS BRAKE SENSOR 1SET 4PIS (RM250)
9.WIRA 1.8 & SATRIA GTI ABS BRAKE SENSOR 1SET 4PIS (RM250)
GEAR BOX & LSD
1. LSD FOR EVO123 VR4 4G93 GSR TURBO (JAPAN OPTION PARTS) (RM 1100)
2. EVO123 4G93 [4WD] LONG SHAFT (RM 10O)
COOLING SYSTEM
1. VR4 RS & WIRA & EVO 123 RADIATOR (RM 100)
2. RACING OIL COOLER 17 ROW 12" X 11" (RM 200)
3. OIL COOLER 6 ROW 25" x 4" & 2" (RM 100)
4. VR4 RS A/C COOLING COIL (RM 50)
5. VR4 RS A/C SWITCH 1SET (RM50)
RACING PART & ACCESSORIES
1 .PERSONAL GEAR KNOB (RM80)
2.WIRA 1.8 MANUAL METER (RM 350)
3. WIRA SIDE MIRROR [1 SET] (RM 80)
4. WIRA 1.6 1.8 ALTERNATOR (RM 100)
5. VR4 & EVO123 ALTERNATOR 75AMP (RM 100)
6. VR4 RS VIPER MOTOR (RM 50)
7. VR4 RS METER CABLE (RM 30)
8. HOT BIT RACING COIL [MADE IN JAPAN] (RM 100)
9. VR4 RS STEERING SHAFT & COLUMN SWITCH & COVER (RM 100)
10. CUSCO BONNET PIN 1 SET NEW (RM 150)
11. EVO 8 RS2 TITANIUM TURBO (RM 1700)
12.CARBING ALUMINUM OIL CATCH TANK 90% NEW (15mm) (RM250)
13. KANCIL INTERNAL MIRROR (RM50)
14. VR4 RS BLOW OFF VALVE & PIPING (ORI) (RM50)
15. VR4 RS TURBO INTAKE HOSE (ORI) (RM50)
16. EVO 123 TURBO INTAKE HOSE (ORI) (RM50)
17. EVO 7 HOLOW CAM (ORI) (RM800)
SOUND SYSTEM
1. SONY XR7190 [MADE IN JAPAN] (RM 100)
2. ALPHASONIK EQUALIZER (RM 50)
3. MANEX HI POWER STEREO GRAPHIC EQUALIZER 100W+100w(RM100)
4. HONDA CIVIC 2WAY MID RANGE & TWEETER 1SET (ORI) (RM30)
5. CAR TRAFFIC BIT SOUND SIREN MADE IN USA 5"X6" 90% NEW(RM120)
ORIGINAL LAMP
1. HONDA CIVIC SH4 TURN SIGNAL LAMP (ORI) (FRONT) (R&L) (RM100)
2. HONDA CIVIC SH4 BUMPER LAMP (ORI) (FRONT) (R&L) (RM100)
3. HONDA CIVIC SH3&SH4 REAR CENTER FRAME (RM30)
4. HONDA PERLUDE REAR CENTER REVERSE LAMP (ORI) (RM80)
5.WIRA REAR LID LAMP (REAR) (R&L) (RM80)
6.WIRA REAR TURN SIGNAL LAMP (ORI) (REAR) (R&L) (RM100
7.WIRA REAR NUMBER PLATE FRAME (ORI) (R) (RM40)
8.CAR SUNROOF COVER UNIVESE 7"X36" (RM30)
9.CAR WIND GUIDE SUNROOF COVER 6.5"X38"(RM50)
CARBING ALUMINUM OIL CATCH TANK 90% NEW (15mm) (RM280)
PRO TORNADO SAVE FUEL & MORE POWER FO WIRA 1.6 & 1.8 (RM50)
ALL ITEM CAN SEND BY COURIER WITHIN MALAYSIA
For any INFORMATION, TECHNIQUE SUPPORT or PRICES kindly contact H/P: 016-4514155
ELECTRONIC
FUEL PUMP
INJECTOR
SARD SILICONE HOSES
EXHAUST
SPARK PLUG & CABLE
1.
SUSPENSION
BRAKE SYSTEM
GEAR BOX & LSD
COOLING SYSTEM
SOUND SYSTEM
ORIGINAL LAMP
TEIN HA ADJUSTABLE SOFT HARD & PILLOW BALL UPPER MOUNT FOR TOYOTA JZX 100 (F) (RM450).jpg20.3 KB · Views: 1,282
CAR TRAFFIC BIT SOUND SIREN MADE IN USA 5â€-6†90% NEW(RM120).jpg22.7 KB · Views: 92
