strut bar improve handling n reduce bodyroll?
kaninbu
669
104
1,543
seriously city n highway driving needs it?or improve the look of the engine bay?
stutzedward
3,416
561
It certainly helps but if you don't corner fast, no point. Just adding weight only. I dun hv any in my car.
pwhyze
924
356
1,563
Agreed with above. If you want to improve cornering, thicker anti roll bars would help more than strut bars.
6UE5t
6,000 RPM
6,756
1,300
Strut bar is to make the chassis more rigid in case you corner really2 hard, attacking apex curbs, or do jumping which causes the chassis to flex (like in racing or rallying). So unless you do those things often, then no need to get a strut bar. Better spent your money on better dampers, springs, and anti-roll bars than strut bars.
YYC
1,833
939
Strut bar is functional for chassis strengthening, no matter you are a slow driver or corner freak and that thing is working. It is not expensive. Worth the investment.
Dayline668
1,828
492
1,683
Car chasis n body is design to flex for improve NVH n improve body absorption when impact, euro NCAP for the main reason, if they wan it stiff will just made it like roll cage cheap n easy. Strut bar if street use it will channel more NVH into the body, track use rollcage n the more bar the better for rigid chasis.
As for antiroll bar do improve handling, but for stiffer antiroll bar = more understeer, need to tune your handling altogether to get the best result.
kaninbu
669
104
1,543
99% of time driving a car is on straight road.stil worth it?
conclusion nt much need in city driving.right?
another myth just busted....
6UE5t
6,000 RPM
6,756
1,300
Yeap exactly. It has benefit but is it worth it for daily normal driving? IMHO not really. Of course if the factory standard car already has it then no harm there, but to add to cars that don't, I'd rather spend the money else where which will give me more value for the money.
kaninbu
669
104
1,543
r u taking 180km/h corner?if do,it help very lil bit.if u go ultraracing webpage.it explains all but they r toking in highspeed driving.
Similar threads   Forum
saw 1 620kg, another one 500kg but not sure whether is is rp02 or not.
just wanna know more about this, is it light weight? Made in Japan one
Thanks
