Steering Wheel Vibrate When Cruising Above 100km/h
zLWinter
21
Hi guys, i would like to seek for helps & opinion :banghead:
When i drive above 100km/h above the steering wheel keep vibrate, the vibration even worst when i step more on the pedal.
Car : Myvi 2011 model with 15' aftermarket rim ( SSR @ made in china or taiwan i guess ) with continental cc5 195/55/15
What i did :
On wheel & off wheel balancing = DONE ( already went to 4 different tyre shop with " timbang kuda " )
Alightment = DONE
Tyre = Check no problem, no swollen, all round.
Tie road = Check no problem
Steering rod = Check no problem
Engine mounting = check no problem
Disc rotor = previous using stock caliper & stock rotor also vibrate, now upgraded to honda ra1 caliper & rotor still the same
Rim = Check no problem, no dent & already fitted with center cone perfect fit.
Driveshaft = change 1 set left & right on march 2013, claim another new set left & right from workshop YESTERDAY 23/7/2013.
What the workshop foreman told me was it might be the driveshaft problem so he proceed for warranty claim as previously he gave me 1 year warranty, but after changing to another new driveshaft (left & right )vibration still the same :mad:
Now he suspect might be the driveshaft qualify bcoz it is not a OEM driveshaft from perodua, he ask me to top up a little bit of $ and go for the oem driveshaft IT MIGHT can solve my problem
I would leave the mechanic and swap the tyres around. Front to back then see if the vibration feels different. I suspect uneven tyres.
Not typically visible and can only be felt and even then it's felt only by seasoned hands
desmond0318
467
48
528
I had the same situation last time while i need to fill high air pressure for daily max load (230kpa front, 215kpa rear) we have bouncy tires with more air inside >_< but it fixed after reducing back to 200-190. Hope it helps with the easiest way.
On wheel balancing done properly?
Base on what you have done above, probably you may need a center cone to centralized the wheel if this have not been done.
zLWinter
21
Went to the same workshop again...This time they gave me another set of 15'inch rim and tyre, tested in on mrr2 just now. I would say vibration 70-80% reduce :driver: ( cause they jz simply did on wheel balancing )
Conclusion : Either is rim quality problem or tyre problem. Btw foreman already check the rim, no bent, no crack.
Change rim first or tyre 1st ? :confused:
kazukimy
638
372
1,563
KL/Pahang
devil-home.blogspot.com
on my situation, rims is the issue, where i need to go bck to the tyre shop, and he had to run 4times on wheel to finally get the mark spot on, as i bought the rims from them, hence they need to do it,wakaka
stupidcar
5,000 RPM
Mar 18, 2013
5,567
850
Replica has a weird weight on random sides. Different spokes with different weight too. A lot.
As so I heard.
xMika
623
85
Selangor
tyre problem .. try swap rear to front ! had the same problem as well but just fixed it 2 days ago ..
My question to you is have your rims been repaired before? Were the bought 2nd hand? If yes do you know the history of the rim? Some rims repair jobs are done meticulously well but they affect balancing hence causing the vibrations. Some are repairs a bit too out of proportion and all that good stuff.
If they were bought new then it's most likely one of the tyres that's out of balance or unevenly worn or worse - manufacturing defect.
zLWinter
21
Already did X rotate, vibration still there.
---------- Post added at 11:16 PM ---------- 6 hour anti-bump limit - Previous post was at 11:11 PM ----------
I bought it at rawang, new set of rim. I didn't send to any workshop to repair and already send to few workshop to check for bent / crack, everything ok.
Today i walk in to the same workshop again, change 2 pieces of new falken 912 & did on/off wheel balancing.
Result : Vibration still the same, so i would confirm is the rim problem. Maybe i kena conned by the rawang sales staff, it might be a refurbish rim and they re-sell it as a new rim.
---------- Post added at 11:19 PM ---------- 6 hour anti-bump limit - Previous post was at 11:16 PM ----------
As so I heard.
Ya, u are right. Previously i thought it was the tyre problem and i change 2 pieces of new tyre place in on the front to check for vibration. Sadly after i change the tyre and fiitted back to my rim the vibration still there. I would say it's the rim qualify problem.
Similar threads   Forum
Wheel And Tyre
Looking For
Honda
I would like to know diff. between the MIVEC RS vs MIVEC BLACKTOP ecu, anyknow about this?
Whats the diff. for rechip and reprogramme ecu?
If i go for rechip/reprogramme my blacktop ecu, will i get better performance than the rs ecu?
What actually you all did on the progress?
I think mommom can answer my question, but before i proceed i would like to make my self clear, so anyone here can enlighten me?
