Steering pulls to right and left
jebatdex
430
18
518
Skudai, Johor
Guys, I had this problem for my car. When driving on uneven road, the steering feels it is pulled to right and left (depending on the road). Is it a time to do alignment (and balancing too, i know balancing dont cause this, but sekali jalan la), or absorber problem? Alignment done 1 year ago.
Front absorber never changed by previous owner, car come into Malaysia from Japan in 2015. The car is made in 2010. Rear absorber changed 6 months ago.
15,390
Generically speaking theres a few possibilities :
1. Tyre thread pattern is causing this.
2. Some bushes at the arm area is worn out and unable to hold the wheel straight when pushed against uneven roads
3. You have an overly sensitive power steering rack which isn't a bad thing. Just get used to it unless the pull is too aggressive.
4. Your alignment is out somehow but that's unlikely.
gunnerzz
Jul 3, 2014
2,109
695
713
38
Melaka
worn out steering rack bush or worn out tie rod.
Worst case is worn out steering rack. On some model, the slack/freeplay can be adjusted to reduce the effect.
jebatdex
430
18
518
Skudai, Johor
How is the steering on flat roads?
on flat is ok, nothing weird.. problem when coming to uneven roads. as simple as crossing the straight road white line (the line is parallel to my car direction), lets say from right to left (or either way), I can feel slight pull.
jebatdex
430
18
518
Skudai, Johor
So, for instance, should I just do alignment first to see hows it different? Cheapest and fastest. And if not working, maybe go to other costly way. Or maybe during doing alignment, the tyre shop ca possibly point out where the problem come from?
gunnerzz
Jul 3, 2014
2,109
695
713
38
Melaka
dependa on the tire shop..some decent one will highlight the issue and tell u to fix that issue firts before doing allignment.
I will fix it first as changing the parts will require allignment too, thats double cost if u do allignment first.
jebatdex
430
18
518
Skudai, Johor
yeah, u got the point. so now, need to look for a good and honest alignment shop. anyone can recommend one in JB?
30,002
If on flat road is okay, I don't see any problems. Probably like bro, Izso mentioned over sensitive steering.....
gunnerzz
Jul 3, 2014
2,109
695
713
38
Melaka
If it does not happen before then its not tramlining.
My waja on 205/55/16 experience these before and its due to worn out steering bush rack.
My Pajero LO on 265/70/16 with 8jj rim also exp this and its due to the wide tire. Its not that bad as the steering got tons of free play. Now back on stock alloy and using 255/70/15 so far dont feel anything.FC is super duper good though.
jebatdex
430
18
518
Skudai, Johor
Maybe due to wide tyre I think, because Mark X car same age as my car not having problem with steering bush rack yet. My car milage not even 100k yet some more. Maybe good idea to do balancing and alignment first? RM60 at most i think?
Background information:
Total mileage travelled per month: 3000km
Fuel consumption: 8.1L / 100km 85% highway; 15% city
Average speed on highway: 80-100km/h
Average speed in city: 20-60km/h
Local car with monthly instalment of RM 460
Question:
Should I change my ride to a 2nd hand car with a more efficient petrol engine or a diesel engine?
or
Screw it, just stick to the current ride.
Appreciate all your sound advices.
