Spring rate for adjustable
alienklipsch
Mar 14, 2012
13
Penang
What is the best spring rate for adjustable front and rear?my rear is bouncing like hell when go thru uneven road like suddenly higher road then down again...currently with 4kg on rear!
ehdrian
I Don't Care!
3,310
280
1,683
Penang
yr absorber is soft hard adjustable type?..if yes then adjust softer..
ronzai89
30
to get the best settings, you must know what you really want.
Understand your car well 1st, then only you will know which to upgrade.
if its too bouncy, means ur spring rate is too hard. Go and get a softer spring.
if you really want to get comfort settings, pls skip adjustables.
^pomen_GTR^
7,000 RPM
7,509
1,690
The Mines
what car??myvi???
perhaps 2.5-3k rear and 4k front is more than enough....
4k rear definately bumpy coz myvi rear is really featherweight....
jackocc123
Apr 5, 2012
7
what is the best spring rate for persona ??
Front I use Mines @ 4K but rear one I haven't change I use improve comfort but feel a bit uneven.
so what is the best rate for persona??:confused:
fstr
7,000 RPM
7,934
954
3,213
Sahara Desert
if u have transplanted ur engine, its wise to change to 8k for the fronts and 5k for the rear, this is to support your heavier engine...
if its standard for wat mau put so so high?
^pomen_GTR^
7,000 RPM
7,509
1,690
The Mines
my satria on 4k rear also still quite firm....small car use 4k rear jialat leh....
try 2k spring or 3k max
hi all...
i need some advice from u ppl out there regarding my turbine..
i'm using b6 turbo...everytime my turbo ons, which means the boost meter goes more than 0.1, white smoke will be coming out from my exhaust...its pretty alot at times...i duno whether my turbine oil seal has any prob or is it my turbine itself...but then the power of the car remains the same...
plz assist me on this...tq..
