Sportex exhaust!? HELP!
Shobzz09
Aug 31, 2011
12
london
Hi guys,
So, I posted a thread before but no reply, but basically, I have a VW polo, Mk4, X reg (2000) and I'm buying a sportex exhaust, do I need a racetube? Or will the backbox do? What difference does a racetube make?
Thanks
xtremeleo
3,247
464
iam sorry nobody replied ur previous post, i dunno about the term u used but iam assuming a backbox is a muffler and racetube is the straight through bullet when replying this sir. i dunno about the diameter of the pipe, but as my thumb of rule, i match a muffler for the torque delivery dat i like and use bullet(s) to help the muffler to muffle the zorst noise
xtremeleo
3,247
464
there are a lot of race tubes in the aftermarket, their function is primarily to deaden the zorst noise imo sir. although ive found tubes dat can alter the zorst flow, but id rather use the rear end muffler for dat
Havok_KiD
579
23
well likewise hat Xtremelo said... a bullet or what u define as race tube is used to to reduce the sound db of your exhaust and certain bullets are used to give you some good back preasure...
but in some cases... getting a good backbox/muffler will just do the trick with some good route piping to it
So basically all I need is a backbox??
Shobzz09
12
london
Ok, thats perfect, cheers everyone
---------- Post added at 11:44 PM ---------- 6 hour anti-bump limit - Previous post was at 08:58 PM ----------
Guys, Instead of buying a backbox, will a muffler just do?? What does a muffler actually do?
Thanks
xtremeleo
3,247
464
sure, get the longest muffler dat can be installed behind the bumper, with the proper diameter. then, if needed trim the noise down with race tubes. original aftermarket's zorst like apexi comes with at least 2 race tubes for the skylines. cheers sir
upontheriversky
275
82
apart from muffling noise, u will need a racetube that has much bigger diameter than ur collector pipe for best performance. in exhaust pressure wave point of view, it separates ur header and collector length from backbox/tailpipe end so header and collector length is kept tuned.
with racetube separating the 2 parts, ur exhaust system appear "shorter" to the engine for best peak power otherwise with no racetube, the engine will see ur collector pipe to backbox as one long pipe and reduce ur peak power hp
Dear all.
ANy Brands of small car vacuum Recommend ?? Sure with your satisfication and reasonable price..
Let us know where can get it...
I saw 1-2 vacuum selling cheap in Brothers and also Parkson.Arond RM 12.90-16.90. I have no dare to buy it...affraid regret.
Welcome your suggession and opinon.
Thanks,
Stanley
