Sport rim size and tyre
LORD_PITZ
63
1,508
Need help with all guys...
i use wish 2010 model.....now want to change tyre and sport rim....today had drive from rawang then go to klang in searching of rims and tyre....1st had decide to use 17inch rims,but in my mind i dont want too many gap at fender side....is it 17inch or 18inch that i should use also what tyre that you guys recommended that maybe pricing between rm300-rm400
There will be no larger gap if you change to 17" or 18" if you use the right tyre size, but if you want lower profile then there will be larger gaps in between.
What is your original tyre size?
Supra_Fanatics
Beyond 20,000 RPM!
20,673
3,998
Go 215/50/17 then get lowered springs? :biggrin:
Supra_Fanatics
Beyond 20,000 RPM!
20,673
3,998
MPV lowered what for?:biggrin:
Cuz got gap not nice ma...lowered for VIP style MPV. Like many of those VIP style Alza haha
At least Wish looks better
LORD_PITZ
63
1,508
I agree if want to losing the gap,bttr i change..spring,also all shop from rawang suggest me to use 215/50....just right now confuse to buy 17 or 18....also what type that suit to my wish...
Supra_Fanatics
Beyond 20,000 RPM!
20,673
3,998
before you can go 18". Need to know what is your original tyre size?
LORD_PITZ
63
1,508
Now use bridgestone b259 195/60r16 with standard sportrim for wish 2010
---------- Post added at 09:43 AM ---------- 6 hour anti-bump limit - Previous post was at 09:41 AM ----------
That my tire
---------- Post added at 09:45 AM ---------- 6 hour anti-bump limit - Previous post was at 09:43 AM ----------
I hope that i can get suitable s/rims and tire by tommorow due rite now i drive on poor tyre..
Supra_Fanatics
Beyond 20,000 RPM!
20,673
3,998
Best size to go still is 215/50/17.
225/45/18 exceeded the 3% by 0.01% :biggrin:
But gonna be bumpy ride than usual. If with sports springs even more :biggrin:
Correct me if im wrong :rolleyes:
LORD_PITZ
63
1,508
214/45/17?...i think this size will be more gap at rr....or should i change frt tyre different with rr tyre
6UE5t
6,000 RPM
6,756
1,300
Best to use 215/50/R17 which will reduce your fender gap by >3mm and still within the tolerance from std size. Use rim size 17x7 or 17x7.5
---------- Post added at 11:46 AM ---------- 6 hour anti-bump limit - Previous post was at 11:44 AM ----------
use 215 45 17 with 7.5/8jj rims
Yes, 215/45 is actually even smaller diameter than std size, hence will increase the fender gap and the tire is getting too thin so will be a bit harsh ride.
Do not use staggered sizes coz your car is FWD.
---------- Post added at 11:47 AM ---------- 6 hour anti-bump limit - Previous post was at 11:46 AM ----------
Ok what, to make handling even better. Basically to make it a station wagon. :)
LORD_PITZ
63
1,508
Ok...so that mean better i take 17 sport rim then use 215/50 rite
That is why I mention use the correct size tyres. 215/50R17 you mention is correct but is actually bigger then the original so how can it have more gap? You simply think that going 17", lower profile automatically more gap.....:banghead:
---------- Post added at 02:33 PM ---------- 6 hour anti-bump limit - Previous post was at 02:29 PM ----------
See, bro. 6UE5t also mention is bigger how can gap more?.....hahhahhaha:biggrin:
Yup, Use stagger tyres cannot rotate then problem, use spare tyre also problem....
Then might as well buy a wagon......hhahahhahahaha:biggrin:
6UE5t
6,000 RPM
6,756
1,300
Correct! Best use 17x7.5jj with 215/50/R17 tires. Test fitment first on the car before paying to make sure the offset is still fine within the fender and no touching on the inner parts when do full lock turns. Choose rims that fits nicely and also the lightest you can afford so that your acceleration, braking, and FC would not suffer.
Staggered on FWD also makes it more understeer. If RWD then ok to use staggered sizes. :)
Wagon don't have 7 seats, so best is buy MPV then lowered it! :biggrin:
Offset 42 normally fits pretty well. Advanti and Konig have light weight rims around RM1600 for 17".
I used staggered before when upgrading from 16" to 17" as wanted to finish off my 16" tyres. 205/50R16 front, 215/45R17 rear, but once the balance of the 16" finished all 17" dy.....:driver:
LORD_PITZ
63
1,508
Refer above konig and advanti.....this 2.model i dont see it when make tour from rawang to klang...where do if i want to find it maybe sunway rite
Supra_Fanatics
Beyond 20,000 RPM!
20,673
3,998
What is stagger tyres? No under the stand...:hmmmm:
Ya I thought profile lower then gap bigger haha!
Tee 3 Auto & Tyres selling ori Advanti. Konig will be Hup Shun like Izso mentioned.
Similar threads   Forum
Proton
Looking For
Daihatsu
Proton
Similar Threads
Hi,
Just wanna check, I'm driving perdana evo 3, semi lsd gearbox, my front driver side driveshaft has broken, can i replace it with original perdana's driveshaft
