Satria Neo Cheap Engine Upgrade
frank118
435
24
Looking for cheaper solutions to give the engine a little more oomph.
The standards are air intakes and exhaust...what other less exspensive alternatives without messing to much to the ori engine???
mie77
88
Plugs,cables,pulleys,lighter rims,quality engine oil...mostly P&P stuffs u can think of without "opening" the engine...
frank118
435
24
Well...trying not to spend too much with the recession going on right? 1k - 2k still affordable. But I need recommendations on where to go too...not very familiar with KL...been away for a long time.
wormyx
57
Hello there,
Why don't you come over to Satria Neo Community at Satria Neo Club. Over there you can learn so much about any performances,handling,grooming,driving and many more.Have a visit.
Regards,
Max
lapsap25
208
Voltage stabilizers..less than 1k, and many friends claimed that it helps a lot..
Zeroed
1,706
45
In my opinion (and experience)... get a good exhaust manifold like Powerzone, remove the cat. converter (you can keep your midpipe and muffler), change the airfilter and you're good to go. You may consider lightenned crank pulleys (but there may be side effects from losing the dampener - even mythology's is only half dampened), or if you can find, a lightenned flywheel (this one guaranteed improved pickup).
Other than these the rest are, IMO, very marginal gains for the money you spend. Only do those after the above... until you are prepared to spend big for big mods.
SubaruFTW
Nov 27, 2012
23
503
Miri
go with volt stabilizer. My Satria Neo CPS had a volt stabilizer and it feels like the pick up has increase. not by a HUGE MARGIN, but yes there is a good feel in pick up. it doesn't even HP but it helps the spark plug to give more spark during combustion.
ken yeang
6,618
1,327
increase ommph = increase spending
HP and performance involves moolah, in the automotive world.
Sup zth, how you fellas been... ill try to post up some of the DIY's that I was able to take some photos...
This is installation is on an RB but it would apply to I would say most cars with a few changes here and there...esp at the wiring or sensor adapters installation. So if you're installing other makes, this guide can still be used. If at any point you are not sure of something just ask away. For this ill be doing Oil temp, Water Temp and Oil Press.
In this kit. What we will need...
