Saga Abs and Spring need help
Skyfiro A32
82
Hi all sifu,currently i own a saga lmst with all the time heavy carry in the trunk.wanted to noe which type of abs and spring can be adv for heavy carry needed?mech suggest to take honda's spring for rear but some other mech not recommend cz honda's spring doesn't fit well wit saga space.its smaller than saga oem spring.need to noe is honda's spring recommend for saga rear and gas or oil type abs more suit?:stupid:
SkYwAlKeR
10,139
300
ePoh ~ malacca
mitsubishi super touring springs... stiffer spring rate.... but u will need to chop the springs as they are damn blardy tall...
honda sm4 spring also ok... stiffer spring rate compare to oem....
bumpy or not lain cerita la.. haha...
just wanna know whether ur ori clutch will slip when u change gear in high rev?
need feedbacks from all turbo user with std clutch. thank you
