- Jan 2, 2004
- 348
- 0
- 3,016
Dear Guys,
Got a problem. I'm currently contemplating whether to change to a metal head gasket for my GSR engine. The problem is, whether to change to one that is 1.2 mm or 1.5 mm. If so what are the pros and cons? Also, I've heard that the thicker the gasket is, compression would be lower. If that is so would changing to a 1.5 mm gasket also lower my torque (pickup) from the lower RPM ranges?? I'm just running stock TD04 turbine on my setup and I'm currently boosting 1bar with the help of a boost controller. Any suggestions? Any sifus out there any comments or insights would help regarding the differences between the metal head gaskets. Your comments are appreciated
