- Jan 9, 2006
- 1,116
- 5
- 1,638
PS-PowerSport designed Easy Launch Control unit features an extremely smooth [soft-touch] rev-limiting action without rough engine back-firing at the startline to prevent wheel spin or engine bogging-down enabling very consistant race results.
More info.@ www.ps-powersport.com
The PS Part number: ELC-705 allows you - YOURSELF to dial the rpm you desire at the front of the unit, no need for expensive tuning service to set your rpm which make you drive off the line like a Professional driver.
Quantity in stock: 10 sets each for type SP & SN
Normal Price:RM$980/set. Stock clearance now for only RM$780/set.
Dimension: 24mm[H] x 58mm[W] x 92mm[L]
Part No: ELC-705. suitable for most stock or aftermarket ignition system.
*Type SP for ignition sensors with positive +12 volts activation.
*Type SN for ignition sensors with negative ground activation.[/img]
_________________
Sam. Tel:016-812 1121
Speed Syndicate [M'sia]-Sales & Tech.Associate.
Other Dealers enquiry welcome!!!
_________________
