Proton bags first points in IRC at Spain
Dinesh
Dinesh
770
1,700
1,593
Proton marked their best finish yet this season in the Intercontinental Rally Challenge (IRC) at the Rally Islas Canarias El Corte Ingles in Spain as driver Giandomenico Basso brought his Satria Neo S2000 home in ninth place for a well deserved two points for the driver's championship and 16 points for Proton in the manufacturer's standings.
The results in Spain puts Proton fourth in the manufacturers table, behind leaders Skoda and Peugeot and just two points adrift of Subaru in third. The ninth place finish made Proton the best of the Asian manufacturers in Spain as well, ahead of Suzuki, Honda and Subaru as well as European manufacturers Citroen, Renault and Ford.
Based on the standings, it isn't a surprise that the top eight in Spain consisted of Skoda and Peugeot machines with the defending IRC champ, Juho Hanninen, taking the win ahead of Skoda teammate Jan Kopecky. Peugeot's Thierry Neuville was third in his 207 S2000. Although Basso was 49 seconds behind the eighth-placed driver, Bruno Magalhaes in a 207 S2000, he was ahead of the tenth-placed driver, former World Rally Championship driver Toni Gardemeister in a Skoda Fabia S2000, by 48 seconds.
“It's a positive result to start with the new team. I think we did a good job and now that the event is over, we will be discussing what further improvements we can make to the car with as there is still a long way to go in the championship,” said Basso.
Basso's teammate, PG Anderson, came in 16th after losing plenty of ground on the first day, having suffered from two punctures. After switching tyres following the first puncture, Anderson was forced to take on the sixth special stage with a slow puncture as there wasn't another spare tyre. As a result, he dropped to 19th at the end of the first day but fought back to finish 16th.
The second round of the IRC was contested on the little Spanish island that sits just 100km off the coast of Africa. A total of 12 special stages covering 190.59km made up the rally. It attracted 35 drivers in the IRC field with Peugeot being the most represented manufacturer, having six 207 S2000s on the field, followed by SKoda with five.
“While the Satria Neo S2000 has benefitted from a number of enhancements, we arrived at the rally fully realizing that the competition will be extremely stiff. A top 10 finish and securing 16 championship points is nevertheless encouraging, proving that we are progressively moving forward and getting more competitive. Above all, it tells us how much more is required,” said Proton Group Managing Director Datuk Sri Haji Syed Zainal Abidin Syed Mohamed Tahir.
skazareth
skazareth
473
110
1,543
powered by Renault for 2.0
powered by i.6T proton
also a rumor...
darkness3299
darkness3299
138
6
well, whatever it is, its cool to see that finally proton is using its neo to compete. cant wait for them to enter WRC. :proud:
4roda
4roda
97
That is some info for S2000
technical specification
1) 4-cylinder 1998cc DOHC normally aspirated (NA) engine is based on the 1.8 litre Renault engine in the Waja.
2) 280hp at 7,800rpm
3) 271Nm of torque at 7,000rpm
4) Xtrac 6-speed sequential transmission with Alcon clutch and 3 player LSD.
5) Brakes from Alcon, with 300mm discs with 4 piston calipers at the front and 300mm discs at the rear on gravel.
6) For asphalt, the front brake discs are uprated to 350mm.
7) Wheels are 18 inch alloys for tarmac and 15 inch alloys for gravel.
8) Electronics system runs on the GEMS Multiplex System with Power Management, Data Logging and a Glass Dash Display.
andrew_lsp
andrew_lsp
52
12
1,508
the spec given was last year car now they increase the power output to 305hp
as well the supplier for the suspension has change
The Neo S2000 has collected some improvements over last year mainly in the suspension and engine For the former MEM has worked together with Dutch company Reiger for a setup that has more travel and with less friction in the dampers Engine wise, they worked on the mid range for a stronger punch out of corners with less need to downshift This complements the already strong top end response
