Pre-Tuned Unichip Dastek for Mit Airtrek Turbo
ivan_pitworks
262
Unichip 32 bit version(one model just before the "Q" version)
comes with plug & play harness from Japan(male & female adapter to original ECU & harness)
The Unichip is connected to the harness, you just need to disconnect the original ECU harness &
plug in both the ends to this connector.No splicing of any original harness!!!
Previous car owner is dynoed at 280bhp on crank, 41.9nm torque with the correction factor on the
dynopac machine @ 1.3 TCF, dyno sheet will be provided @ point of purchase for verification
at point of tuning, car is only fitted with HKS pod filter, HKS SQV BOV, Straight Tru exhaust, Trust FMIC.
no upgrades to fuel pump or regulator(stock turbo).
So if there are any bros out there with similar setup, this is good for your ride.
Selling at RM800 for the Unichip & harness together. ( this unichip is pre-tuned by Australian tuner ) Its easy plug 'n' play !
( I used for only 1 month , response at rpm5k push u back into your seat ):biggrin:
Interested pls call : +6012-7170051
Item Loacation at JB !
Hi Mod sifus... Just want to ask your opinion on this...
I have a wira 1.6 Aeroback with Promote Bumper... Currently using APM Sport Springs but it is too low...
So was wondering if changing to Eibach Prokit would it solve the issue above? I know the comfort would be much better...
Or changing to Adjustables a better option? You get the height and comfort? The other day I went to Kakimotor.com and they recommend me to get HWL, and claim it can be as comfortable as Eibach... is this...
