Power FC, need boost controller?
ahloy74
46
6
508
n sembilan
Hi all sifus,
If i were to use Power FC to adjust my fuel and ign signal, do i still need boost controller?
What i understand is boost controller is to control desired boost up to factory setting. By using
Power FC, the setting can be elliminated. So why is boost controller ever reqiured?
Unless for safe fuel setting, and track setting....Am i correct? Thks.
Slowboy
160
27
528
Power fc as an ecu to control engine parameter also it can be done for boost controller but need seperate device.
Boost controller to adjust desire boost lets say 1.2, 1.3 and so on...
kojai
291
17
malacca/jb
i m using power fc but problem with idling rpm, no idling bro. Already changed trottle body but it same problem, any advice
ahloy74
46
6
508
n sembilan
Bro kojai, we are not sure wether your pfc or your car is at fault. I suggest you plug your pfc on your friend's car( having same model) and find out. If the defect transferred means your pfc is faulty( provided your friend's car idling is ok before that) if not, you got to troubleshoot your car system. Just my opinion...
[PIMPIN]
2,138
648
3,213
You can perform a sensor check under the ETC menu when the key is in ignition turned to ON position. There you can see if there is a problem with any of the sensors. Good place to start at least.
rodondo22
71
5
1,508
hello friends,
Some clutch will contribute in knocking no.Is it true?
Does Mega-Rich setting will eliminate knocking?
Similar threads   Forum
Car Modification
News and Features
News and Features
Toyota
Similar Threads
This just in. Think the new Type-R is the JDM story of the month?
Even before the launch of the New Honda Civic Type-R, Mugen has already been secretly developing their own tricked-out version of the Type-R. What they've done is aesthetically biased, though there is visual drama in the engine department. We'll just have to wait for their full announcement on the Mugen...
