Pls help : Eterna gbox.
analyzer125z
4
Hello everyone, i am new to this forum and i am seeking guidance for my eterna gearbox.
I am currently running eterna TT auto gbox, and i wish to change it to manual. However, i am only able to find the complete manual gbox set minus the gear pedal and clutch pedal.:mad:
My questions here are:
1) is it possible to modify the VR4 or Evo 1-3 gear pedal and clutch pedal to fit to the manual gearbox?
2) If possible, can anyone recommend a workshop in Puchong/ Sri Kembangan/ Subang Jaya/ USJ area that can do such mod?
Thanks for any input.:burnout:
mag9556
2,770
43
1,648
Actually I have a fren whom is using V6tt with 4G93 NA Gb.. 63 wise not sure about it.. but with 93 Gb u will have a bit slip...
Good Luck..
To make the story short, i currently change my front and rear brake to e5 brembo, the front i use e4 knuckles since it plug the front brembo with just one lower arm ball joint replacement,and use back oem abs sensor, the rear i custom bracket to fit the caliper, use back ori abs gear and sensor with custom bracket and proper sensor spacing...
When all the mod done, i went for teasting, discover the brake pedal sinked to the metal while i apply brake, brake not functioning well and need...
